12-19-2009, 07:15 AM | #1 |
Newbie Join Date: Oct 2008 Location: Phoenix
| Mongoose Help
I recently installed a Mongoose 13.5 and my pinion gear does not seem to be correct. I'm running a 13t pinion but I'm not happy with the gear mesh. Can someone direct me to the correct one. I also have problems with a dead spot when I go from forward to reverse. Does anyone now how you program around this? Thank you in advance.. |
12-19-2009, 09:56 AM | #2 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
What is wrong with the gear mesh? Did you use the blue pinion that came with the motor? You might want to go down to a smaller pinion. I am running an 18.5 with a 13t i think and it is good. You need to adj. the DEAD BAND (when the blue and green lights are on). How is the drag brake in the 13.5 or do you have the crawler esc?
12-19-2009, 11:36 AM | #3 |
I tried setting the dead band as low as i could. The drag brake is ok. Does not hold as good as stock did. My setup did not come with a pinion.
12-19-2009, 09:39 PM | #4 |
Quarry Creeper Join Date: Jun 2008 Location: Honolulu
Are you using .5 mod pinions? And to utilize the crawler profile on the esc you must use the 18.5 motor iirc. That might be why you have a dead spot.
12-20-2009, 11:17 AM | #5 |
Quarry Creeper Join Date: Nov 2009 Location: San DIego
I just got the esc and 18.5 motor combo, and mine seems to be fine. Only trouble I had was the motor plate had to be dremeled for the pinion and motor screws to line up. The new pinion was catching on the motor mount.
12-21-2009, 10:44 AM | #6 | ||
Quarry Creeper Join Date: Mar 2006 Location: SoCal
You can always email tech@teamnovak.com with your question, during regular CS hours. Before emailing, take a moment to review the instructions (trouble-shooting guide) originally included with your Novak Item: Novak Instruction Downloads Quote:
