12-21-2009, 01:06 PM | #1 |
Rock Stacker Join Date: Nov 2009 Location: New Ipswich
| Quick question on lipos
I just got my charger for my lipo batt and its asking me what A. I want to charge the pack at??? Is that the Mah rating? Example I have a 5000mah 7.4 20c batt does that mean 5.0 A? |
12-21-2009, 01:47 PM | #2 | |
Pebble Pounder Join Date: Oct 2009 Location: Chattanooga
Most of my packs are smaller, 1300mah so I charge them at 1.3A. Some packs can be charged at a higher rate, if so they will probably be marked that way. You can always charge them at a lower rate without causing problems other than long charge times but should use caution is charging at a higher rate. | |
12-21-2009, 01:50 PM | #3 |
Thanks man I just started charging it now!!!! One more question though... On the charger's display it says the finished voltage will be 8.4v (2s) is this wrong... Did I set something wrong? I dont want to over charge my 7.4v pack!!! |
12-21-2009, 02:01 PM | #4 |
That's correct. I run 3S and a fully charged battery shows 12.6. The actual voltage capacity is a little higher than the battery voltage rating. There is a wealth of info in the electronics section of the forum. If you search for lipo charging you will probably find more than you ever wanted to know. |
12-21-2009, 02:44 PM | #5 | |
