12-31-2009, 07:09 PM | #1 |
Rock Crawler Join Date: Dec 2009 Location: Ontario Canada
| Got a LiPo for my Airtronics M11
now..can I leave it plugged in in the Transmitter? or is it like an ESC with a LiPo where it's always "on" even if you switch it off?. like if i leave it plugged into the TX will the battery continue to drain even after shutting off my radio? leading to an over dis charge and ruining my Lipo as well as my M11 radio thanks. it's a Losi 2400 3s Lipo |
12-31-2009, 07:21 PM | #2 |
Quarry Creeper Join Date: Jun 2005 Location: Las Vegas
I've been using lipo's in several transmitters for over a year now... I only take them out/unplug to charge them I recharge at 10.9-11.0v. NEVER EVER charge the battery with anything but a lipo charger... no wallwarts! Making the mistake of leaving the TX on will cost ya a battery |
12-31-2009, 07:25 PM | #3 |
ah ok. yea i've got an Onyx 230 charger and a Ultra balancer from Common Sense RC...it's all i need so If i leave the battery in the transmitter while it's turned off I should be ok? and thanks for the quick reply. |
12-31-2009, 07:30 PM | #4 | |
01-01-2010, 08:57 AM | #5 |
Quarry Creeper Join Date: Mar 2009 Location: Texas
I put a lipo in my M11 as well. I only take it out for charging. I have had mine for about 4 months, and all is good.
01-01-2010, 10:04 AM | #6 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
If you know you won't be using it for awhile, like a couple of months, unplug it. But I'm like the other guys, I only unplug when I charge.
01-01-2010, 10:12 AM | #7 |
if i were not going to use it for more than a week or so i would do a storage charge/discharge(11.4v) since its better for the lipo in the long run to be stored at this voltage rather than full charged.
01-01-2010, 10:23 AM | #8 |
Quarry Creeper Join Date: Dec 2008 Location: other side of the track,the bad side
01-01-2010, 02:33 PM | #9 |
I'm using a Fusion Pack 1300 3s. I know its a little on the small (mah) side, but it works just fine.
