01-04-2010, 04:09 PM | #1 |
Rock Stacker Join Date: May 2008 Location: oregon city
| novak 45t
no matter what motor i run in my scx-10 it over heats.....just got a 45t and dont want to burn it up.....any help on why this may happen sidewinder cc bec pro @ 7volts hs 645 spektrum 3s batteries |
01-04-2010, 04:48 PM | #2 |
Pebble Pounder Join Date: Jan 2008 Location: canada
are they 27turns or lower? my stock motor in my wheely king and ax10 both 27t got hot when i was crawling not so much when bashing when i got my novak 55 all my heat issues went away. put it in and run it touch it every few seconds and c if its getting hot. if it is shut it down! Also check your gear meshing if its to tight the motor has to work harder.
01-04-2010, 05:13 PM | #3 | |
all that i have tried are 55t or higher and the the 45t for more wheel speed....just redid the mesh and messed with the settings on the bec and sidewinder so we'll see how it goes | |
01-04-2010, 06:08 PM | #4 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
the bec will have nothing to do with burning motors up, but its set at 7 volts??? thats a bit high for running a 645, might burn a servo up doing that.
01-07-2010, 07:55 PM | #5 |
Pebble Pounder Join Date: Dec 2005 Location: MODESTO
pinion gear go smaller |
01-08-2010, 10:14 AM | #6 |
Pebble Pounder Join Date: Dec 2009 Location: Silverton
I run a Novak 45 T motor with a 12 pinon gear and a rooster ESC and lipo 7.4 that i charge to 8.4 and my motor never gets hot. If you have a load problem or the gears are binding you will over heat. You may want to check all of your running gear for any tight spots and then check your out put to your motor with a meter. You may not be getting enough power to the motor and that would cause over heating.
