01-11-2010, 11:28 AM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: Perrysburg
| FXR -AMP DRAW??? small lipo packs ok?
Anybody know a ballpark amp draw for a fxr? I am looking to downsize my lipo packs, Right now I am running 3s 2200mah 35c packs on a dual fxr berg with 13t pinions, ccbec @7v -hs7950th servo and 45t motors.I want too downsize to around 1000-1300mah packs but i don't want too lose my "punch" .So what it all boils down too is what C-rating do I need? Thanks, |
01-11-2010, 12:09 PM | #2 | |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
? if you mean total amps, then you can already peak over 60amps with your current set up. However Continious amps are want you need to look at. I would think that you would be safe at 45amps. So 1300 mah at 40 c would be close. I know of people who run alot less, its all up to you. Its not good to overamp a lipo, but I have done this on numerous occaisions, and consistantly. Never a problem yet. Just saying. | |
01-11-2010, 12:12 PM | #3 |
Quarry Creeper Join Date: Oct 2009 Location: St.Louis
If you don't want to loose any punch you will need to get a high discharge C rating and a high burst rating on the pack. I have used the 1300 2S lipos from Holmes hobbies with success. Might want to check them out. Not to pricey either |
01-11-2010, 12:14 PM | #4 |
I normally run 11.1v 1250-1500mah 20c's on my berg setup with 35t's and Fx-R. No issues. Lots o' punch. I would really like to find some 40c's but $70 for a very small lipo seems overkill with 20c's and 30c's working good. Just bought two 1000mah 11.1v 30c's here. Bought 2 to try them out. http://www.valuehobby.com/product_de...=8&item_id=111 |
01-11-2010, 12:27 PM | #5 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
| I'm running thunderpower 850 45c http://www.aero-model.com/Thunder-Po...C-Battery.aspx and can tell the difference from the hyperion 1300 25c I was running. |
01-11-2010, 03:41 PM | #6 |
Thanks for the links guys,Those gforce lipos look tempting for 13 bones and not from china. kinda iffy about cheap lipos as I have never ran any, but alot of people are having good luck running them.
01-11-2010, 04:07 PM | #7 |
Ya do understand with that gforce you are going from a 77amp discharge rate (2200mah x 35c) down to 30 amps (1000mah x 30c) don't ya. It also looks like that 30c # is burst not continuous. The little thunderpower 850 has a 90c burst (850mah x 90c) for a 76.5amp rate so ya don't lose "punch", only but run time.
01-11-2010, 04:18 PM | #8 |
Quarry Creeper Join Date: Oct 2009 Location: Indiana
I going to lhs to get a male deans for my esc in the am. Then I'll let you know about them G-Force. I have the 1300mah 30c's.
01-13-2010, 12:04 AM | #9 |
So far so good. Both packs are balanced perfect. 40 minutes run time and never went below 6.6v.
01-13-2010, 07:30 AM | #10 |
Newbie Join Date: Dec 2009 Location: Kansas City
I have a 1000mah and a 1300mah on the way ill let you know how mine fairs. |
01-13-2010, 07:40 AM | #11 | |
I will buy one of those Thunderpower's to try em' out. I will gladly pay $36 for that TP pack. | |
01-14-2010, 07:16 PM | #12 |
Just found another good deal on some china packs but still contemplating on unknown names,just trying to save a buck! Anyone use these before? http://www.aero-nuts.com/product_inf...roducts_id=610 |
