01-14-2010, 08:21 AM | #1 |
RCC Addict Join Date: Feb 2006 Location: Bellflower, CA
| Quick FXR help!
I just installed the FXR in my SWX comp rig with dig. Question is when i hooked up the motor wires to the correct tabs with the throttle in normal setting the motor spins in reverse. I could do one of two things: 1 reverse the throttle on the TX or 2 swap the motor wires ( + to neg tab and - to pos tab) on the motor. When i had my rooster, Novak said the motor is not polarity sensitive but somewhere in Tekins instructions, it says to connect the motor wires correctly. I guess having the dig and mirrored tranny cause this. What should i do?
01-14-2010, 08:29 AM | #2 |
Rock Crawler Join Date: Jan 2009 Location: Boise
Just swap the wires on the motor and call it a day. |
01-14-2010, 08:40 AM | #3 |
Thanks! will do.
