01-14-2010, 10:02 AM | #1 |
| Is This Battery/Motor Setup Retarded?
I am looking to get a bit more speed on my waterproofed mudder/basher SCX10. I have an AX10 for crawling so the SCX10 serves nothing more than as a submersible trail blazer. I am running a Titan 12T 550 size with a 20T pinion on the stock 87T spur with an XL-5 ESC. I want the max voltage the ESC can handle so I want to use a 9.6V NiMH hump pack from MaxAmps. http://www.maxamps.com/MA-5000-8Cell-Hump.htm# Would this be a bad idea? Will the motor or ESC overheat too fast? |
01-14-2010, 11:27 AM | #2 |
RCC Addict Join Date: Jun 2009 Location: California
If the ESC can handle the volts than it would be fine. The only way I could see your ESC freaking out is if you rig has some speed/power and ya are bashing it to much...More watts = More power = Faster rig = Hot motor temps = Hot ESC. Just keep a eye on everything, you should be fine. |
01-14-2010, 08:29 PM | #3 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
nother way to look at it...the mud might keep everything cool...
