01-14-2010, 03:49 PM | #1 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
| Low "c" taring vs. motor draw???
Someone was curious about my battery choice VS. the motor that it's feeding. I'm running a Integy 35T motor with a B1R ESC with a 3s 1250mah, 12C battery. The thing is crazy fast with the gearing its got and nothing has gotten hot yet. I thought Kaetoe had run this same combo in his review but the C rating was higher. ????, is, Is it to little of battery if it's working fine so far? or am I in danger of doing damage to the battery or ESC? Don't see a problem yet so whats the scoop, will the motor draw too much that the battery can give it or will it hurt the ESC?:?
01-14-2010, 03:55 PM | #2 |
my rig would hit lvc everytime i tried to climb at half throttle with that batt, you'll notice alot more punch from a real batt instead of the tx batt.
01-14-2010, 04:03 PM | #3 |
Rock Stacker Join Date: Nov 2009 Location: Killingworth
Essentially... you are running a Heli combo. I may be off but I swear I recognize the numbers. With 12C of "flow" or discharge you're fine. You'd notice heat if you weren't. It's a bit like running a 20T -24T pinion - thus the crazy fast. But a 3S (11.1v) 12C 1250 mah is indeed a battery for Heli's (400 Class actually)
01-14-2010, 04:06 PM | #4 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
I used to run 20C (I am guessing BURST since no burst was listed) 11.2v 1500mah packs......I thought that they were great....that is until I dropped in a 40C continuous (50C Burst) 11.1v 1050mah pack. WOW. The difference was dramatic. I am convinced that running a lower C rated pack may work, but you truly do not get the maximum from the truck running those packs. I would not want to give up my 40C packs. |
01-14-2010, 04:33 PM | #5 | |
01-14-2010, 04:47 PM | #6 | |
the pack the op is running puts out 15 amps peak, my 8711, 9650 and fan and rx can probably almost draw that. it's like trying to piss with a raging hard on. | |
01-14-2010, 06:02 PM | #7 | |
RCC Addict Join Date: Jun 2009 Location: California
Its like what most people have problems with the Losi MOA like I did...The two HH35T I was running pulled so many amps combined, plus the worms didn't help that. To get max power/amp draw with run time I got a 45c 2250 4cell...Talk about power. Only problem was the lipo was so dam big it made my chassis weight to heavy and I didn't like the way it crawled..One reason took my MOA back to shafty.... | |
01-14-2010, 06:15 PM | #8 |
Those are pretty much the answers I was expecting. Thanks. This was never intended to compete with and I've actually tuned down the F/R speeds from the remote just to keep it from faster than I currently want it too. We'll see I guess when I have a chance to get it on some rocks but I'm happy with, I just didn't want a lipo fire or to burn up the ESC. |
01-14-2010, 09:01 PM | #9 |
the fact that it'll cut off as soon as you ask for power is all that'll stop it from popping the lipo.
01-14-2010, 09:20 PM | #10 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
When you lower the C rating, you get a crappier low end throttle resolution and work the batter harder than a battery of the same capacity and a higher C. It would be like racing a Geo next to a Ferarri. The Ferarri will have to work alot less hard to produce the same power and speed... I wont touch anything under a TRUE 25C... |
