01-16-2010, 06:03 PM | #1 |
Rock Crawler Join Date: Aug 2008 Location: maple ridge
| I want to bump my Servo Voltage to the max
I have the CC bec and i want to turn it up to power the servo at its max voltage rating (the servo's) Is this safe? and is this how your wupposed to wire it? is there any negative side effects of this or will i have the retarded servo power i'm looking for. i'm using a JR z9100t servo. spec: JR Z9100T Digital Ultra Hi-Torque Surface Servo (Metal Gear) [JRPSZ9100T] MAP Price: $139.99 This is the JR Z9100T Digital Ultra Hi-Torque Surface Servo. Monster truck owners in need of the greatest steering power possible will love the Z9100T Ultra Torque servo. With the same case size as the 9000 series, it's an easy upgrade, and the red anodized aluminum heat sink case keeps things cool in demanding conditions. Features
Type: Ultra High-Torque Digital Servo Torque: 300 oz/in @ 4.8V, 370 oz/in @ 6V Speed: .18 sec / 60 degrees @ 4.8V, .15 sec / 60 degrees @ 6V Dimensions: 0.83" x 1.59" x 1.57" Weight: 2.3 oz Gears: Metal Gears |
01-16-2010, 06:09 PM | #2 |
Pebble Pounder Join Date: Nov 2009 Location: ft collins
wires look right but can you get a servo that is about the same performance but cheeper? like hobbico cs170 333 oz of torque at 6.0 volts titanium gears and only 90 bucks TCS crawlers.
01-16-2010, 06:10 PM | #3 |
Pebble Pounder Join Date: May 2005 Location: hot springs, AR.
you batt. will go dead with the bec on that side of the plug.
01-16-2010, 06:12 PM | #4 |
i already own the servo. can i go over the factory spec say bump it up to 6.5V? or do i even need to wire it liek this at only 6V I'm running a JR300 receiver. do you think that woudl be able to handle the 6v? |
01-16-2010, 06:13 PM | #5 |
ya i noticed that. This image is robbed from another thread. i wont be hardwiring the BEC into the bat...especially since its only a 1300mHa and i have 3 of them.....
01-16-2010, 06:17 PM | #6 |
I don't know about going over factory voltage spec. You might let the smoke out of your servo. I would not do it . can you change anything else on your rig to get more turning power ????? like take out a high steering kit or go with a behind the axel steering kit so the linkadge moves the tires from a more centered point on the axel
01-16-2010, 06:18 PM | #7 |
Pebble Pounder Join Date: Apr 2009 Location: Gresham
I'm running 6.3v through a futaba reciever and so far so good. Wiring direct to the servo would eliminate the possible risk of damaging your rx, but I think if you max out the voltage you will need to upgrade the wire to the servo. If you don't, you could have a melt down.
01-16-2010, 06:23 PM | #8 |
i can't change the steering because the rig isn't built yet. i have a shafty i compete with and i'm waiting on the new chassis. i want this bully to be 100% what i want right out of the box. i think i will contact JR to see what they think of this. I don't want to void the warranty on the servo but i want the best steering i can get. |
01-16-2010, 07:04 PM | #9 |
Newbie Join Date: Dec 2009 Location: Kansas City
JR makes HV servos that run on 7.4 2s direct lipo. I have run their 8711 in my heli at 7v no problem over a year till I got the HV versions.
01-16-2010, 08:01 PM | #10 |
my 8711 stays cool at 6.2 and i've been thinking of bumping it up. just go a little at a time and feel for heat.
01-16-2010, 09:26 PM | #11 |
Pebble Pounder Join Date: Mar 2004 Location: Calgary AB Canada
I've been running an 8711 at 7volts for well over a year and have had zero problems with it.
01-16-2010, 11:06 PM | #12 |
how much more power do you guys notice with the higher voltage?
01-17-2010, 12:51 AM | #13 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
if your wanting to run higher voltage to the servo, get a high voltage servo thats designed for 7.4 volts. now im not 100% sure, however wit ha 7.4 volt servo you may be able to wire it directly to a 2s pack, and that would supply 8.4 volts at full charge. i would check with the manuacturer first though. fwiw, nitro stuff has used 5 cell packs to power the radios for years. 5 cells is 6 volts nominal, however 6.75-7 volts is normal for a fully charged pack, and running normal servos rated for 4.8/6 volts, ive never heard of anyone having an issue. |
04-21-2010, 11:16 AM | #14 |
Rockin' in Reno Join Date: Mar 2010 Location: Reno
| Quote: He said that you should run the wiring the way it is shown on the BEC card that is included with the BEC. He said most rx's will handle the 7.4v without a problem. |
04-23-2010, 10:26 PM | #15 |
Pebble Pounder Join Date: Apr 2008 Location: bfe
8711 same price and has 403 tq @ 6 v
