01-18-2010, 08:58 PM | #1 |
| Help, I think i just fried my servo
Well i was out crawling to today, and i got a small puff of smoke which i wasn't sure where it came from. So i just got to looking at it and noticed that my servo is having serious problems:-(. it is a 7955tg. So whats happennig is that it will still crank right with what seems like full power, but nothing left. but if i try to twist it to the left with my hand it won't budge but to the right i can do it freely, It seems very strange to me since it still kinda works, could this be because the circuitry got fried, and can i replace it. (i Can't believe i fried it because i was only crawling for 1 battery pack, and it wasn't even hot when the smoke puffed out from somewhere, And it was like 15 degrees outside when i was crawling) if you guys need a vid to help explain i can get one
01-19-2010, 08:07 AM | #2 |
Quarry Creeper Join Date: Jun 2005 Location: Maryland
I just found an issue with a buddies Airtronics 94780 Servo. His would be very hard to turn at times, I had to borrow it for a comp. Worked great all day. Took it home, Wouldnt turn to the left. Turns out if you take the top case off and look at the underneath of it. There are the 2 brass bushings for the side gears and the hole for the output. The center brass bushing hole was all wallowed out. It would line up sometimes and not others. Put alot of strain on the servo which would make it really hot and do weird things. Never let out the smoke. May take a look there for binding. |
01-19-2010, 02:06 PM | #3 |
Did yours make any sounds when it wouldn't turn. mine won't make a sound at all to go one way
01-19-2010, 05:20 PM | #4 |
If it is the circuitry can i use circuitry out of another servo, i have the 225mg sitting in a box, could i use that
01-19-2010, 06:02 PM | #5 |
Well i just opened up the case and yea i burnt up part of the circuitry, its the black thing on the outside edge, any idea if this can be replaced |
01-19-2010, 06:14 PM | #6 |
Quarry Creeper Join Date: Dec 2008 Location: other side of the track,the bad side
hitec has excellent customer service. put it back together and send it to them with a copy of your recipt, and they will fix it free and send it back to ya |
01-19-2010, 06:19 PM | #7 |
| I've got an email going out to them tonight with my problem we'll see what they say, does anyone know where a diagram is to put this thing back together properly (theres to many gears)
01-19-2010, 06:30 PM | #8 | |
Newbie Join Date: Jan 2010 Location: Deering, NH
01-19-2010, 08:44 PM | #9 |
ok, i think i figured out how all the gears go, but i think i got dirt in there when i opened it up so i'm gonna clean all the gears but what type of grease should i use and how much, i've been using hi-temp disk- and wheel bearing grease in my lcc axles, will this work for the servo
01-20-2010, 06:47 PM | #10 | |
01-21-2010, 05:32 PM | #11 |
well i called hitec and they won't tell me nothing other than i have to send it in, hopefully the email i sent them will get a different reply
01-22-2010, 11:10 AM | #12 |
01-22-2010, 02:07 PM | #13 |
01-22-2010, 02:56 PM | #14 |
01-22-2010, 03:20 PM | #15 |
| i did't ask hitec what they put in it, i was emailed them about my circuit board, its a grey grease, it probably is litium but i put some lithium grease in it that we use for our big equipment like skid steers and trackhoes, probably the wrong stuff oh well
