01-19-2010, 04:12 PM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: fremont
| 18.5 ballistic vs. 18.5 goat
What is the difference between Novaks 18.5 Ballistic motor and the 18.5 Goat?
01-19-2010, 04:25 PM | #2 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
Ballistic motor has interchangeable stator and has a larger rotor (14mm vs 12 mm).
01-19-2010, 04:28 PM | #3 |
RCC Addict Join Date: Jun 2009 Location: California
The Ballistic is more of a tuner crawler motor. You can replace winds, and so on. Like I just ordered a Ballistic. Will be at my door on 01/20/10. 18.5T 14mm Sintered Rotor = more power...The Losi crawler systems are 13.5mm Ceramic Bearings Check out there site....Its build a Ballistic crawler motor. http://www.shopatron.com/products/pr....8180.0.0.0.0? |
01-19-2010, 04:37 PM | #4 |
sounds nice! Thank you for the help
01-19-2010, 06:14 PM | #5 |
Pebble Pounder Join Date: Dec 2009 Location: virginia beach
they also have a motor chart on there site the ballistic is 1650 rpms and the non ballistic is 2700........here is a link to the chart i prefer the non ballistic 18.5 http://www.teamnovak.com/products/br...spec_chart.htm |
01-19-2010, 11:52 PM | #6 |
When you click on the build a Ballistic crawler it says its a 2700kv. Duno what was up with that chart. |
01-20-2010, 12:08 PM | #7 |
the 1650 for the ballistic is correct, the stronger magnet slows it down. A member on here informed novak2 that the chart was wrong that listed the ballistic at 2700 and they were supposed to fix it.
01-20-2010, 12:48 PM | #8 |
Ahh. That is low KV for a 18.5...I hope the wheel speed will be good...It will have more than enough torque though.. |
01-20-2010, 02:01 PM | #9 |
RCC Addict Join Date: Aug 2007 Location: Seattle
Ballistic > unsealed can = more maintnance Goat > sealed can = less maintnance |
01-20-2010, 06:02 PM | #10 | |
Ok...Just got off the phone with Novak. This is information everyone should understand, and I think its one more reason to buy this motor..Yes its a tuning crawler motor...What does this mean exactly. I currently ordered the 18.5 Ballistic with the 14mm Crawling Sintered Tuning Rotor, I thought that this was going to give me more torque/power with the same 2,700kv! Wrong! The Link below is the proper kv for the 14mm Sintered Rotor. http://www.teamnovak.com/products/br...spec_chart.htm The point being, is that the motor can be tunned anywhere from a 2,700kv with there 12.5 Sintered Rotor threw 1,650 with a 14mm Sintered Rotor, and so on. You can pick up more sizes at teamnovak.com. I always wanted to try the different KV's like from a 21T - 17.5T but not have to buy more brushless motors...This is a big plus in my book for someone who likes to tink with rig setups. Quote:
'The motors are also equipped with a custom-silicone gasket seal to keep dirt and debris from damaging the motors’ sensor plug' Didn't exactly see anything about the can itself being sealed..But I think it will manage. | |
