01-07-2006, 01:41 PM | #1 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
| n00b question about TR2
I can't seem to get the quick tune to work on my rebel 2. How long should I be holding the trigger in before i push it to the brake position? Also, should I only go from throttle to brake once? The light still blinks after I release the trigger.
01-07-2006, 01:50 PM | #2 |
Pebble Pounder Join Date: Sep 2005 Location: Canada
the manual should explain it all.
01-07-2006, 01:58 PM | #3 | |
01-07-2006, 02:10 PM | #4 |
you keep the button down until it blinks red(10-15seconds). give it full throttle, then full reverse, then you let it go to neutral. led should be solid red. done. check if the connector in the receiver is in the right way and your radio is working.
01-07-2006, 02:30 PM | #5 |
It never stops flashing when I release the trigger. The receiver works in the truck I removed it from. I have also tried 2 different radios. Do you think I may have bought a bad esc?
01-07-2006, 02:38 PM | #6 |
Quarry Creeper Join Date: Nov 2004 Location: MANVILLE
check the settings on the radio.the instructions should say where to set it at
01-07-2006, 03:04 PM | #7 | |
