01-27-2010, 12:25 PM | #1 |
Quarry Creeper Join Date: Sep 2009 Location: Ukiah
| Set up help
Ok so I have a fx-r, ccbec, hitec 7955tg, and ko ex ur pro5(or whatever ist called), do I need to unplug the ccbec to set up the radio and ecs and do I need to set up the esc and bind the radio separte? Thank you for help in advance and sorry about the spelling. |
01-28-2010, 09:05 AM | #2 |
Does no one have an answer to help me out? I did try searching so just post a link if I had missed it or something |
01-28-2010, 11:36 AM | #3 |
RCC Addict Join Date: Apr 2009 Location: Anderson
First you need to bind the radio to the reciver. Then you can setup the ESC. Not sure if you have to unplug the BEC or not. Not to familier with the radio you mentioned. -Jason |
01-28-2010, 12:12 PM | #4 |
Do I bind the radio and reciver without anything pluged into the reciever or do I need to get a reciever pack. I am just asking for a general idea of the order to do things in cause the manuel was clear on how to bind but didn't say anything about if the ecs needs to be pluged it to the reciever or not. So just a general idea of the order of doing things will be very helpfull.
01-28-2010, 12:16 PM | #5 |
Quarry Creeper Join Date: Dec 2009 Location: At your moms,she says hi!
well usually the receiver gets its power from the esc.so if your battery is connected to your esc then you can bind your radio. also if you have your bec connected like its shown on the package you have to plug the middle wire back in on the esc connection before you can program the esc
01-28-2010, 12:35 PM | #6 | |
01-28-2010, 12:43 PM | #7 |
You don't have to. The main thing you HAVE to have is power to the reciver. I can be via a BEC, the ESC, or reciver pack. It just has to be powered up to bind the two. -Jason |
