01-29-2010, 11:40 AM | #1 |
RCC Addict Join Date: Sep 2009 Location: Bradenton
| why is my reverse faster then foward?
took out stock axial esc and put in a traxxas xl-5.I matched my wires red on red n black on black.now reverse is faster then foward.could it be that the wires coming out of my motor a little thinner then the wires coming from my esc?thanks
01-29-2010, 11:47 AM | #2 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
| reverse the wires on your motor/esc and it will be faster forward or just go buy a Novak Rooster Crawler ESC and it will be fast forward and reverse.
01-29-2010, 12:57 PM | #3 |
did anyone else have this problem?
01-29-2010, 12:58 PM | #4 |
the motor ur using likely has the timing retarded slightly, thats how stock axial and tamiya motors are which will make it spin faster one direction. changing tthe esc will not change it, the only way to change that is a new motor with an adjustable endbell.
01-29-2010, 02:13 PM | #5 |
Quarry Creeper Join Date: Oct 2009 Location: Indiana
| What he said. I have a xl-5 and Had the same problem. Adjust your timing if its adjustable.
01-29-2010, 04:45 PM | #6 |
01-29-2010, 04:59 PM | #7 |
Reverse the wires on your motor, then flip the switch on your radio for the throttle channel. See if that fixes it.
01-29-2010, 05:21 PM | #8 |
Rock Stacker Join Date: Dec 2009 Location: midland
I'd go with what duuuude says. The wires on your motor may actually be reversed, so switch them and try it. Also try reprogramming the speed control as well.
01-30-2010, 06:49 AM | #9 |
thanks i'll try it
01-30-2010, 12:30 PM | #10 |
Pebble Pounder Join Date: Oct 2005 Location: Near D.C. (Centreville)
re-program your xl-5 useing the one touch button. Here is a link to the manual that will show you how to set your throttle end points. This should help.. http://www.traxxas.com/PDF-Library/2...705_manual.pdf page 17 |
01-31-2010, 01:02 PM | #11 | |
