01-13-2006, 11:55 AM | #1 |
Pebble Pounder Join Date: Dec 2005 Location: Yorkshire, UK.
| which motor for my maxx.?
Its come to the part of my SA maxx build up to fit the electronics. Ive done a search and havnt realy found the answer. Which motor is best? The choices i have are a mag mayhem or similar and a gd600, OR a 55/65T laithe motor. Im running a 72/9 gear setup with 6" tyres, which setup would be the slowest and most torquey.? Can i run a laithe motor with my evx shorted to run one battery.? Help is greatly apreciated cos i have the money waiting to go my LHS in the mornin and get the guts! Thanks. |
01-13-2006, 12:25 PM | #2 |
Pebble Pounder Join Date: Aug 2005 Location: Fresno
I am running a 55t lathe with 72/10 gearing on a modded(shorted) evx. Lots of torque, great run times. My only complaint is that I wish it had a hair more wheel speed, I am considering making a 7 cell battery to acomplish that. I have never ran a gd600 but everyone that runs them seems to be happy, i just think that simplier the better and if you run a gd600 you have to get that mounted up have the shaft turned down and then you have the added weight up high. But you do get a little bit more wheel speed with gd600 and 27t motor, pro and cons to every situation.
01-13-2006, 02:21 PM | #3 |
Thanks, thats just what i needed to hear. My prefered style of crawling is really slow. but yeah a bit of wheel speed is needed at times. I think ill go for the laith motor, 55T. Wouldnt a higher tooth pinion componsate for extra wheel speed and still have PLENTY of torque? Thanks! |
01-13-2006, 02:43 PM | #4 | |
