02-23-2010, 12:13 AM | #1 |
Rock Crawler Join Date: Sep 2008 Location: Salem,Oregon
| wont turn
so i bought a esc off here its a moped. will go forwards and reverse great. but my truck will not turn could that have something to do with esc. when i had a diff esc on here it all worked great .. is there anything i should try before say i got a bad esc? thanks
02-23-2010, 12:18 AM | #2 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
Turning has nothing to do with the ESC. It's the servo that does the turning. Make sure you've got the plugs in the reciever correctly, usually that's all black/dark wires to the outside. |
02-23-2010, 12:27 AM | #3 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
sounds like the Moped's BEC isn't strong enough for the servo, try pulling the red wire from the servo plug and plugging in a external BEC or receiver pack |
02-23-2010, 12:27 AM | #4 |
yep everything is pluged in right just tried another esc and it turns just wont turn with moped hum....
02-23-2010, 12:28 AM | #5 |
02-23-2010, 12:29 AM | #6 |
What slobin3d said Castle Creations BEC
02-23-2010, 12:35 AM | #7 |
didnt change still wont turn grrrrrr.....
02-23-2010, 12:42 AM | #8 |
ok some how it was the rx. Is there any reason a tq am rx wont work with a moped. but a stock hpi will.. yet the tq rx and lrp esc work together hum....
02-23-2010, 12:53 AM | #9 |
huh what are the chances it was a brokeing pin in the rx that just happen to toch just right with the lrp.. quick sodier and its good
