03-03-2010, 02:15 PM | #21 | |
Quarry Creeper Join Date: Dec 2009 Location: Central IL
I'm not positive though. It'd be easy to check if your receiver was regulating the output to your servo, just hook up the multimeter and look. I guess I've never done it since I've got a BEC. | |
03-03-2010, 04:15 PM | #22 |
Quarry Creeper Join Date: Jan 2009 Location: Hagerstown
Corky I'm sorry I used the wrong word I meant the ESC has an internal BEC my bad. If you are running and external BEC then it will trump the internal BEC. Sorry for the confusion. Zimm I'm thinking you are getting away with it due to the fact that they are in an airplane. Your not binding up the servo or working it as hard as you would in a crawler. When called Hitec CS the first thing he asked me was if I was running the servo in a crawler. We put a lot more stress on our steering servo's than the typical airplace or nitro racer. More stress equals more heat which leads to the magical smoke being released. He recommended a servo prgrammer to set the fail safe. Everything has been good for me since but I did go back to 6v. If you want a faster stronger servo get a 7950. If not Hitec will send you new smoke when your 7955 lets go of the ghost. Make sure you ask for the purple smoke though because they will try and send you the gray stuff that came out the first time lmao. |
03-03-2010, 05:15 PM | #23 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
I put it back to 6v after reading all of this. I agree that you don't really notice a big difference between 6v & 7v. Thanks for the help and answers. On a side note. I moved the drag link to the upper hole on the servo arm and noticed an increase in steering strength. |
03-03-2010, 07:24 PM | #24 |
Absolutely. You'll lose turn radius though. edit: it will increase your turn radius, I knew what I meant haha Last edited by Bray D; 03-03-2010 at 08:18 PM. |
03-03-2010, 07:44 PM | #25 |
Rock Crawler Join Date: Sep 2008 Location: Mid Mo.
03-03-2010, 08:27 PM | #26 |
I wanna be Dave Join Date: Jul 2006 Location: Moscow Mills MO
03-03-2010, 08:33 PM | #27 | |
Small steering mod. | |
03-03-2010, 08:34 PM | #28 |
Quarry Creeper Join Date: Oct 2008 Location: Fresno
Interesting, lots of the racing guys run 7955's on unregulated 2s lipo. They are actually capable of handling the powers says Hitec Reps. It must be the BEC frying the servo.
03-03-2010, 09:09 PM | #29 |
03-03-2010, 11:20 PM | #30 |
| I'm not sure. Maybe the fact that the lipo is going through the receiver then to the servo is what's making the difference. Also mentioned earlier is that crawlers put more strain on a servo. A nitro buggy or truggy won't nearly stress the servo as hard as a crawler in a bind.
03-04-2010, 12:04 PM | #31 | |
| Quote: | |
03-05-2010, 06:27 PM | #32 | |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
over 6 you will eventually burn it up Just leave it at 6v | |
03-06-2010, 11:28 AM | #33 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
The most important issue is EPA. MAke damn sure they are set right. A 7955 will handle higher voltage as long as you watch temps. Rock bashers usually don't watch temps.
