03-14-2010, 02:23 PM | #1 |
RCC Addict Join Date: Jul 2008 Location: San Diego
| Can I use this charger
My Hyperion charger is in for repairs. I have a Ripmax Quattro plus 1-4 cell charger. It say chargers 0.1-3.0 amps. There is no setting on the charger. Can I charge a 1300ma Mystery battery with this charger? These are the specs. http://www.ripmax.com/item.asp?itemid=O-IP2775 Thanks Matt Last edited by SDheavymetal; 03-14-2010 at 03:02 PM. |
03-14-2010, 02:54 PM | #2 |
Pebble Pounder Join Date: Oct 2009 Location: Whitmore Lake
It should be fine, I charg my hyperion batterys at 5 amps. When you first start charging the battery watch it for a few |
03-14-2010, 03:08 PM | #3 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
with no settings on it i have no clue as to how you can charge a battery pack at the correct amperage. most lipo chargers work by starting at a low amperage and ramping it up to your max setting, then dropping it down as you reach max voltage. if this charger works like that and goes up to its 3 amps, i wouldnt charge anything less than a 3000mah pack with it. however im more confused with this as it has a jst plug on it, something for receiver packs. typically a lipo receiver pack is up to 2000mah. im kind of curious on this charger now. i hope someone here has some answers |
