03-15-2010, 10:49 PM | #1 |
RCC Addict Join Date: Jan 2009 Location: ?????
| 8711 losing power?
i just upgraded from a 7955 to an 8711 because the 7955 would get in a bit of a bind and i couldnt get the wheels to turn when "i felt" they should have. now that im using the 8711 and i get the tires in a little bind or when the tires get atona grip it does the same thing. it seems to "run out" of torque when it should still have plenty. make any sense?? i would have thought that going from 333 to 403oz would have taken care of that problem. .. . the bec is new and i got the red wire taken off the esc plug and dono what else it could be. .. .any idears?? thanks in advance. oh yeah, dono if thisll narrow it down any, but im running a dx3R with a BR-XL esc and turnigy 4s 30c batts. .. .
03-15-2010, 11:00 PM | #2 | |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
03-16-2010, 06:39 AM | #3 | |
03-16-2010, 07:38 AM | #4 |
Rock Crawler Join Date: Feb 2009 Location: Chandler, AZ
what steering setup are you using? can you post a pic
03-16-2010, 09:04 AM | #5 |
Rock Crawler Join Date: Nov 2005 Location: Rock-throwing country
Do you have your endpoints adjusted on your radio?
03-16-2010, 02:47 PM | #6 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
I have a 7955 on my LCC now. I was running a 8711 prior to this. I really don't notice that much of a difference in torque. The 8711 I have has developed slop (servo arm moves back and forth) related to the middle gear shaft bushing wallowing out the plastic recess for it in the top case. It has done this twice in the last 6 months. JR repaired it (new case and gears) under warranty once. If you notice the slop starting, re-case (at least the top case) the servo. If you run it like this very long it will mess up the gears. |
03-16-2010, 05:08 PM | #7 |
| i am using the blc ota link with a short little drag link like everone else runnin it. i dont got a camera to take a pic of it. yessir i do. .. . idono what it could be, even if the bec wasnt "needed" that shouldnt really effect anything should it?? should just make it so its a sure thing that its getting the full 403oz of torque right?? |
