03-21-2010, 07:26 PM | #1 |
Quarry Creeper Join Date: Aug 2007 Location: Morrison Crawlerado
| Need help with weird DX3 & Steering Servo Issue
So I recently purchased a DX3 off of Ebay. I've had one before and it worked great. Having trouble with the following setup: HS-7950TH Servo (brand new) SR3000 receiver (have tried with 2 identical receivers) Castle Sidewinder ESC works fine but steering servo glitches and moves back and forth continually. Doesn't seem to respond to transmitter. Also does the same with a cheap tower pro servo plugged into the steering slot. Both servo's work fine plugged into a TQ3 transmitter and receiver with the Sidewinder. Also, I connected the receiver and DX3 to my mini-revo with the vileneon ESC and the hs-85 steering servo works fine. HS-7950TH Servo also glitches when plugged into this system. Am I missing a setting on the DX3???? Why would the servo work fine with the TQ3 setup? Any help is greatly appreciated! |
03-21-2010, 07:28 PM | #2 |
Rock Crawler Join Date: Dec 2005 Location: Huntertown, In
You need a BEC, I had a similar issue and as soon as I hooked up the CC BEC the problem is gone.
03-21-2010, 07:32 PM | #3 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
03-21-2010, 07:36 PM | #4 |
Mine did that same thing, identical set up with 2 different RX/TX. Futaba FM worked, DX3 didnt, put the BEC in it and it worked fine.
03-21-2010, 07:57 PM | #5 |
| Well... I hate to admit it but chalk this one up to the "do I need a BEC?" files. I just hooked up the BEC and it works fine now. Thanks for all the quick replies! |
03-21-2010, 07:58 PM | #6 |
Glad you got it working man.
03-21-2010, 08:00 PM | #7 |
It would not work AT ALL without a BEC?
