04-06-2010, 01:05 PM | #1 |
Quarry Creeper Join Date: Aug 2008 Location: meriden
| timing advance on a 7t puller?
i started to take end bell off of my 7t to clean, when i relized itwasnt going to come off,(pinion had to be cut off,taped motor up but seen some slivers of metal inside can)so i loosened the 2 screws on the brush side of motor a i didnt check position of brushess as it moved freeley around the armature, so my question is could i have adjusted timing or not if its not in the propper position
04-06-2010, 01:10 PM | #2 |
Yes, you can change the timing. Here's the thread for you: http://www.rccrawler.com/forum/showt...89#post1247489 BTW, the endbell screws off if you hadn't noticed that. |
04-06-2010, 02:13 PM | #3 |
thank u for the info
04-06-2010, 02:49 PM | #4 | |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
