04-21-2010, 04:10 PM | #1 |
Newbie Join Date: Feb 2010 Location: Cloquet
| Low run time?
I'm running two 45T silver cans with 13 tooth gears, and a RC4WD outcry esc on my RS10. I'm only getting 45 mins of crawl time on a newer Venom 4600 mAh 7.2V battery. Is this normal? Seems low to me. I'm using an MRC Superbrain 820 charger. Thanks!
04-21-2010, 09:01 PM | #2 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
| Yes that is about normal. Two motors equals twice the power drain.
04-22-2010, 07:51 AM | #3 |
Quarry Creeper Join Date: Oct 2007 Location: Ft. Wright, KY
04-22-2010, 08:43 AM | #4 |
Quarry Creeper Join Date: Oct 2009 Location: St.Louis
| The problem is probably with that Venom Batt. Might want to try another battery of a higher caliber. I have seen many issues with Venom batteries. Then again some people have used them and are happy with them!
04-22-2010, 10:48 AM | #5 |
the problem could be the battery or the motor draw because both of those 45t draw as much as a single 22t so with 2 there is more current draw
04-22-2010, 11:51 AM | #6 |
I'm willing to try another brand. What would you recommend? Thanks for the replies.
04-22-2010, 12:23 PM | #7 |
04-22-2010, 12:42 PM | #8 |
RCC Addict Join Date: Apr 2009 Location: Anderson
Well, we like our Thunder Power packs that we sell! They have a ton of different options! Let us know if your wanting to change from that Venom! -Jason |
04-22-2010, 01:24 PM | #9 |
If you cant go lipo then go to cheapbatterypacks.com. They can build you any battery you want. Get the higher end cells though. But if you can lipo is the way to go. Unless you are scaling, Lipos dont like water at all! SMC is a good battery if you are looking for a stick pack. Just stay away from the cheap stuff when it come to batteries!
04-22-2010, 01:35 PM | #10 |
| Where have you heard this? I thought as long as they don't stay submerged (lightly shorting) for days they're fine...? Like if there is somehow a standing pool of water contacting the pos and neg inside the heat shrink around the pack.... I've been submerging mine for about a year... Am I just lucky? Last edited by Blood_Clod; 04-22-2010 at 01:37 PM. |
04-22-2010, 08:10 PM | #11 |
Thanks guys! I'm not quite ready to go lipo yet. I know that time will come, but for now I'm just enjoying crawling with my friends.
04-22-2010, 10:11 PM | #12 |
Quarry Creeper Join Date: Dec 2008 Location: Hawthorne, CA
In my experience, venom battery packs are worthless. For the same price you can get a dynamite battery pack that will last you a good while. I didn't run my pack for about a year because I use lipos, but I recently charge it again and it works like new.
04-23-2010, 11:21 AM | #13 |
same here my experience with 2 3000mah venom 6cell nimhs were poor after about 10-15 charges they werent lasting quite as long as my 1500mah nicds
