04-30-2010, 11:29 PM | #1 |
Rock Crawler Join Date: Jul 2008 Location: River Falls
| Micro LOSI li-po charger voltage?
What is the output voltage and charge rate for the micro LOSI li-po charger ? http://www.losi.com/Products/Feature...rodId=LOSB0862 I'm trying to see if I can use an old cell phone charger, but it's only 5v... |
05-03-2010, 08:05 AM | #2 |
Pebble Pounder Join Date: Apr 2010 Location: Charlotte
i have one at home I can run a test on when i get back for you most likely... knowing what little i know about lipos Id say because they recommend charging at 1/10 the mah id say its a .15amp charger for the small 150mah. |
05-03-2010, 08:41 AM | #3 |
Thanx man...the rating should be printed on a label on the charger...
05-03-2010, 08:53 AM | #4 |
Even easier. I wont even have to take out my multimeter. ;) I'm out of town till tomorrow around noon. Ill post it up as soon as I walk in the door.
05-04-2010, 07:21 PM | #5 |
So I found a Motorola charger that's 9v and 200mah..should be perfect for my 200mah lipos since cell phone batts are li-ion... |
05-04-2010, 07:59 PM | #6 |
05-04-2010, 09:03 PM | #7 |
Pretty much same technology, innit?
05-04-2010, 11:04 PM | #8 |
