05-01-2010, 04:42 AM | #1 |
Pebble Pounder Join Date: Oct 2008 Location: Belcamp
| hmmmm
ok battery is a thunder power 11.1 2200mah, i have punk dig and a mamba max esc. today i charged my battery full with balance. i have a LCC MOA with 2 35t integy motors. it has always ran great but today it started loosing power when i would use front dig? then about 10 mins later it would do the same with rear dig? any ideas? i was thinking brushes on the motor because i could kinda smell that motor burn smell lol
05-01-2010, 05:13 AM | #2 |
oh yea and my mamba max gets hot really fast? not really hot but it happens within 5 mins?
05-01-2010, 05:52 AM | #3 |
RCC Addict Join Date: Jun 2006 Location: Maryland
Sounds like the motors are on their way out. I smoked a 35t integy on my moalosi to the point that it couldnt be repaired. Try having the com cut, and replace the brushes, or step up to a higher quality motor, (thats what I had to end up doing).
05-01-2010, 08:50 AM | #4 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Its possible you started to burn the windings on the motors.....worn out brushes or the comm needing a cut, rarely cause a burnt smell. Inspect the armature for any burn marks or discoloring on the windings.....if the arm has a burned smell to it, its probably toast. It will still run for a while, maybe even forever, but it will never be at 100% again. Later EddieO |
