05-01-2010, 01:03 PM | #1 |
Newbie Join Date: Dec 2008 Location: spain
| SIDEWINDER incapable of going to reverse I have a Axial AX10 with a CC sidewinder+Integy 55T lathe, that no matter how I try does not seem to go into reverse. I bought the castle Link and it seems OK , all parameter seem OK, but still cant get no reverse. Led goes green when FWD and turns RED when throttle goes to reverse and the Axial does not move. I have a competition in two weeks and need a ESC to run.... HELP can it be that the ESC has not been calibrated??? the calibration does not seem to end up I have thought about the MOPED VR16R bravo as it is cheap and it seems to be simple to configurate OPPOSITE TO THE SIDEWINDER !!!. Will it work with my Brushed lathe Integy 55T? thanks ed |
05-01-2010, 01:23 PM | #2 |
Have you tried updating the firmware?
05-01-2010, 01:48 PM | #3 |
Quarry Creeper Join Date: Oct 2007 Location: Ft. Wright, KY
If I recall when going fwd the led should be solid green and when in reverse it should flash green (not solid red) Im pretty sure... So that tells me that you might have programmed it on brushed non-reversing, I assume you looked for that though... ?? Try to re-callibrate throttle end point again also... |
05-01-2010, 02:01 PM | #4 | |
I have tried MANY times and after the first batch of beeps and lights on the full throttle FWD it goes mad and does not give me the supposed "four rings". Im puzzled Thanks ed | |
05-01-2010, 02:34 PM | #5 |
05-01-2010, 02:37 PM | #6 |
| I got it to work !!
I had to set it to Brushed with reverse lockout. I still dont understand if when I release the "gas" it brakes or simple stops accelerating. Then a second push forward and it will go reverse Finally Thanks to all ed |
05-01-2010, 02:38 PM | #7 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
05-01-2010, 02:41 PM | #8 |
You want forward to brake to reverse, Lockout mode is double pump reverse.
05-02-2010, 04:47 AM | #9 |
Quarry Creeper Join Date: Oct 2009 Location: Indiana
make sure your not set to brushed high power also, you just want brushed. I think the high power mode is forward only.
05-02-2010, 07:27 AM | #10 |
Rock Crawler Join Date: Feb 2004 Location: Michigan
05-02-2010, 09:42 AM | #11 |
forward to brake to reverse is instant.
