05-01-2010, 09:05 PM | #1 |
Rock Stacker Join Date: Mar 2010 Location: wilton, nh
| please help!!
i just got my truck setup with 4 wheel steer, the truck works perfect until i use the rear steer, the problem i am having is after 10-15 second with the rear steer on the truck shuts down. my esc is receiving but it is dead in the water. i have to reset the truck and good to go.......for another couple seconds. any help would be great thanks. here are my components. futaba 3pm tekin fxr hitec 645mg servo (front) stock as2 servo (rear) |
05-01-2010, 09:09 PM | #2 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
Your 2 servos are pulling too many amps from the BEC in you fxr causing it to shut down. You'll have much better luck running an external BEC. |
05-01-2010, 09:13 PM | #3 |
thank you will give it a shot
05-04-2010, 07:33 PM | #4 |
just wanted to give a update, so if anyone has the same problem. i went with a cc bec and all problems solved |
