05-02-2010, 10:37 AM | #1 |
Rock Crawler Join Date: Jan 2005 Location: The Hills
| Looking for more wheelspeed, advice please
I'm running a rooster crawler esc, 55 t novak motor, thunder power 1350ma 2s 30c packs on my scx10 with 2.2 tires. I'm looking for a bit more wheels speed and I'm not sure witch direction to go. I bought the charger and packs less than two months ago as a way to try out lipos without spending too much. Now that I've messed with them and no longer "afraid" of them I was thinking about going to some 3 or even 4 cells packs. That however would cause me to have to upgrade my esc since the novak crawler can only hold 2s packs. I've messed with an old stock 27t in the truck and it's fun but the amp draw is too much and causes quite a bit of heat in the small packs and the 18g factory wire on them. Also, I don't really need as much speed as that old motor can generate. Even geared lower it is still a bit much. I would like to just pony up, go brushless and buy some 4 cell packs but that's just too much coin to drop at once. If I go brushless, would that in itself give me enough wheel speed to be somewhere between the 55 and 27t motors? Will that be a large draw on these "small" packs? Should I just buy a 35 turn motor and some higher ma packs? Thanks for the help! |
05-02-2010, 10:48 AM | #2 |
RCC Addict Join Date: Sep 2008 Location: Mccalla,Al
I would go 35t FXR, Castle, or Holmes ESC, and at least 3s lipo. I think you will like the combo of speed as well as control. Going with a higher mah will just give you longer run times.
05-02-2010, 10:50 AM | #3 |
Pebble Pounder Join Date: Feb 2010 Location: Wenatchee
You arnt really going to get much wheel speed with a novak, i had the same setup and quickly changed it out. I have a 35 turn tekin with a fxr esc and running a 11.1 lipo with insane crazy wheel speed. I think you are going to have to change your motor to see any difference. |
05-02-2010, 10:53 AM | #4 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
being you have the battery packs already, go with a 35 turn. i found 35 turn on 7.2 volts to be enough. the other option is to go 3s lipo, but iirc the rooster crawler doesnt have 3s cutoff.
05-02-2010, 11:07 AM | #5 |
Quarry Creeper Join Date: Jun 2005 Location: Las Vegas
to me a 55T on 3's is about the same wheel speed as a 35T on 2's... so either volt up(can't with the rooster) or buy a good 35T hand wound if it were me I'd be looking at a more versital ESC and some 3's packs... maybe a new motor as well. For me, anything more than a 35T hand wound on 3's is just over kill.... FUN, but still more wheel speed than you really need in a crawler or scaler... unless your rock racing or bashing more than crawling. |
05-02-2010, 11:12 AM | #6 | |
Something water proof would be nice, what are my options there? | |
05-02-2010, 12:03 PM | #7 |
Quarry Creeper Join Date: Oct 2007 Location: Ft. Wright, KY
05-02-2010, 01:19 PM | #8 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
A 35t motor would probably do you well, but a 45t may be more of the ticket if you think your electronics are not up to stuff. The novak 55t is really just a slightly better lathe motor....moving to a nice handwound motor will be a big difference in all terms of power. I don't see why your current setup would not handle a 35-45t.... Later EddieO |
05-02-2010, 02:22 PM | #9 | |
Pebble Pounder Join Date: Dec 2008 Location: Alberta Canada
05-02-2010, 02:37 PM | #10 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
Tekin FXR Pro, a 35t, and a 3S and you'll be happy as a kid in a candy store |
05-02-2010, 05:51 PM | #11 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
I run a Rooster Crawler esc with a Trintiy 27t motor, stock gearing with a 2s 5000mah lipo. Good wheel speed and torque. Have had it in my SCX10 since I built it over a year ago. This combo has never let me down....
05-02-2010, 06:01 PM | #12 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Or ya could pick up a Verlineon brushless set up from someone upgrading a slash 4x4. Waterproof and plenty of wheelspeed on 2s but not really crawler control or instant reverse. A 35t may do the trick for ya if the 27t was too much.
05-02-2010, 07:49 PM | #13 |
Pebble Pounder Join Date: Oct 2009 Location: South Korea
The traxxas combos have horrible low speed control.
05-02-2010, 08:13 PM | #14 |
Rock Crawler Join Date: May 2009 Location: Idaho Falls, ID.
I run a 3s on a rooster and a 55t motor and have good wheel speed but I too want more wheel speed so I'm going HH 35t. I have had no problem with a 3s on the rooster just have to keep an eye on things no cut off.
05-02-2010, 08:15 PM | #15 |
Rock Stacker Join Date: Oct 2009 Location: Fort Worth, TX
Torquemaster BR-XL Waterproof ESC (80Amp continous and 6S rated with a 6 volt, 5amp BEC). Good 35T motor Hyperion G3 VX 3S battery (the battery is subjective, I like the Hyperions but there are other good batteries ou there). |
05-03-2010, 08:22 AM | #16 | |
Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
Try a 3S first (beg, borrow or steal one for a test run) then decide. A Novak Rooster can run 3S, so why not try it first. Seeing that you have considered a new ESC anyhow, it won't hurt much if it blows smoke. My guess is it'll be fine. Cheers. | |
05-03-2010, 09:11 AM | #17 | |
05-04-2010, 09:05 AM | #18 |
I'm sorry if I gave the wrong impression, I don't mean to suggest you just abuse it and toss it. Your question has been asked many times before, and the answer is still the same. The Novak Rooster can take 3S. If you run a 27T motor and 16t pinion (stock RTC) on 3S you might be pushing it, but a 55T with 14t or even a 12t pinion, the Rooster doesn't break a sweat. I've been running mine for about a year like this. What I am suggesting is that you borrow a 3S pack for a quick five minute test and see for yourself. The difference in performance is like chalk and cheese. I firmly believe you would have to be very unlucky to burn your Rooster doing this. Then make your motor, ESC and battery decision with your eyes open. Cheers. |
05-04-2010, 09:42 AM | #19 |
I didn't figure you meant for me to kill it. I was under the impression that the rooster couldn't handle the voltage. I wasn't aware that the issue with running 3 cells is because the esc is setup to shutdown at 80% of a 2 cell pack. I guess I could even run it with an external low voltage warrning device and let it be at that. Too many options, so little money :( |
05-05-2010, 08:31 AM | #20 |
There's been a few threads on this subject. True, it doesn't have 3 cell cut-off. Some say to run an external cut-off, I don't and it's never hurt me. When LiPo's get low the voltage drops like a greasy brick, I just stop as soon as I feel it go. Do a little snooping around, the Rooster is well covered, as is the wheelspeed question and the 2S or 3S question. It's all in here, but ya gotta look. Cheers. |
