05-02-2010, 07:29 PM | #1 |
Quarry Creeper Join Date: May 2008 Location: Hartsville, SC
| Sidewinder Esc on/off switch not working.
K. so I just put my new sidewinder on my crawler since I moved the tekin over to the scaler. Got it all plugged in and plug in the battery and Bang it comes on. I figure I had it on when I plugged it in but no. I can switch the switch back and forth and it stays on the hole time. My set up is Sidewinder Esc CC Bec Jr 9100t servo Hr dig with Jr st126 dig servo Dx3 radio with Losi 3 ch. RX The Bec is wired directly to the battery line, the red wire is pulled out of RX plug. I understand the steering works when battery is plugged in but why the hell would the esc come on with the switch on or off. I'm confused |
05-03-2010, 07:16 AM | #2 |
Quarry Creeper Join Date: Oct 2007 Location: Ft. Wright, KY
I've had 6 or 7 castle speedos and the first three the switches went bad after about a few weeks. So I think they just use cheap switches. Now as soon as i get a speedo I cut it off and just solder it. If you run lipo you have to unplug the battery after every run anyways. Most of my rc friends have had the same problem with their switches. So your switch is most likely broke in the "On" position. Which is unusual cause typically they wear out and loose contact (off postion). |
05-03-2010, 07:26 AM | #3 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
Mine stays on when the battery is plugged in too... BUT only the steering works when the switch is in the off position. So maybe thats normal.? To me this is nice, because if im setting up my steering there is no way the truck will take off.
05-03-2010, 07:59 AM | #4 | |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
I remove my switches and just unplug the battery. | |
05-03-2010, 08:27 AM | #5 |
Rock Crawler Join Date: Sep 2009 Location: My Old Kentucky Home....
05-03-2010, 08:31 AM | #6 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
wow i must have one of those great sidewinder switche's....i leave it in the on postion and "ALWAYS" unplug battery....to get this straight, if i solder the wires together it is in the on postion then, just in case it goes.............bob .... |
05-03-2010, 08:49 AM | #7 |
05-03-2010, 08:50 AM | #8 |
Yep. Soldering them together = always on.
05-03-2010, 10:52 AM | #9 |
I think i'll end up doing that. But it did kinda catch me off guard because the first thing you think of is that its getting power from somewhere else somehow. Now I'm trying to program it manually until get my castle link and when I plug it in it doesnt beep or anything. I need to program it to run a brushed motor. I cant even get it to beep. Does it only beep when a brushless motor is hooked up. The directions tell me to listen to the "4 beeps" I dont even hear one beep. Not even the sound of it initializing. Doesn't look good for the sidewinder. Its brand new too. Just got it in a trade from a vendor (not his fault though it was sealed in the package).
05-03-2010, 10:57 AM | #10 | |
It's ok. The sidewinder is fine. First, Castle speedos come preprogrammed for "Brushless" from the factory. Those beeps you here come from the motor believe it or not. Since it's set on brushless and trying to beep through a brushed motor it's VERY VERY quietly. You need to practically put your ear on the motor to hear but it is beeping. Also you can follow the Light flashes on the speedo. They correspond with the "beeps". Or, if you have a brushless motor laying around with 4mm bullet connectors just plug it in outside you truck and youll hear the beaps loud and clear. Hope this helps you man, I know how electronics can be frustrating! Last edited by Blood_Clod; 05-03-2010 at 11:00 AM. | |
05-03-2010, 11:00 AM | #11 |
you tha man. When I get home from work today I'll check it out. Thanks |
05-03-2010, 11:59 AM | #12 |
Yep, sounds come from the motor, not the ESC. Loud on a brushless, quieter but still audible on a brushed. |
05-03-2010, 12:00 PM | #13 |
| It's still working because you don't use it. |
05-03-2010, 12:03 PM | #14 |
The more I think about it... Do Castle speedos flash with the corresponding beeps? Can you either look at the flashes or hear the beeps? I though thats what I did but not sure now.
05-03-2010, 02:31 PM | #15 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
05-04-2010, 06:19 AM | #16 |
