05-03-2010, 07:20 PM | #1 |
Quarry Creeper Join Date: Jan 2009 Location: Langley, BC, Canada
| Motor break-in?
I just picked up a HH Torquemaster Pro, and wondered if there is a break-in procedure that I should use. I don't wanna damage this little gem! Cheers |
05-03-2010, 07:26 PM | #2 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
I would hope its broken in already, but if not, 5 min a 2.5 volts and 30 seconds at 3.5 volts to finish it....I like to spray a squirt of motor spray with about 5 seconds to go on brushes... Later EddieO |
05-03-2010, 07:26 PM | #3 |
I already broke it in, but you may want to add some advance timing to it to increase the motor life.
05-03-2010, 07:32 PM | #4 |
Wow, thanks for the speedy replies! Noob question...How do I advance the timing?
05-03-2010, 07:34 PM | #5 |
It depends on which is your forward rotation. Basically you want the motor to spin faster in forwards than in reverse. Short of it- Loosen the endbell, rotate a few degrees, tighten. If you look carefully, there are little hash marks on the plastic endbell and a 0 mark on the motor can. Just one hash mark is enough advance. |
05-03-2010, 07:36 PM | #6 |
Kickass! Thanks John!
