05-04-2010, 02:50 AM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: Gibraltar
| Associated Reedy Flash 55X1 Crawler Opinions Please
Hey guys was looking at this motor as an upgrade for my Novak fifty5 what do you guys think about this one? http://www3.towerhobbies.com/cgi-bin...6&I=LXTXG2&P=K i cannot seem to find torque and rpm figures for the novak the specs for the reedy is as follows: SPECS: Length: 2.6" (67.4mm) including shaft Length: 2.1" (53mm) not including shaft Shaft Diameter: 1/8" (3mm) Motor Can Diameter: 1.43" (36.4mm) Max RPM: 9,600 Max Torque: 213N/mm Max Power: 52.3W Max Efficiency: 79% opinions please |
05-04-2010, 09:31 AM | #2 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Well, it's a better teardown base, but its still machine wound, so reallly not a huge upgrade........ Later EddieO |
05-04-2010, 10:19 AM | #3 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
yeah, for that price, i bet you could find a 35T warrior. at least that is a PROVEN motor. actually, for that money you could probabally get a brood motor.... (haven't looked at eddie's site since he's been back...) but, on another note, an Assoc./Reedy crawler motor????? is this a sign that they are going to be offering us up a crawler soon??? |
05-04-2010, 01:34 PM | #4 |
I wouldn't doubt it, but we will see... Warriors or stuff from me will run you some more, but I do think JP has some Checkpoint based 55t or so for around 40 bucks.....check out his site... Later EddieO |
05-04-2010, 01:52 PM | #5 |
Actually, those have been around for a while now, likely at least a year. Pretty sure.
05-05-2010, 12:23 AM | #6 |
could you guys give me some links to this eddie site jp and warrior motors? thanks for the reply you guys noticed the reedy is quad motor too right?
05-05-2010, 12:44 AM | #7 |
The flash teardown has been available since like 2005 or so.....its fairly old. They just finally ordered some from sagami in crawler winds.... http://www.jpcustomrcs.com/Motors.html His Warrior Max is what you want....same price and will blow the Flash away in a heart beat. The quad magnets are nice in the right application, but I am not a big fan of them in 50+ turns....even then, I can tell you there is NO way they will make up the difference of a machine wound arm vs a handwound arm like the warrior has. I make the JP motors, so feel free to order from him, as my site is still getting put back up.....hopefully this weekend! Later EddieO |
05-05-2010, 12:47 AM | #8 |
Rock Crawler Join Date: Jun 2007 Location: Arlington
| Quad magnet. Instead of two magnets that wrap around the inside of the can, they are segmented. Helps torque at low RPMs.
05-05-2010, 01:15 AM | #9 |
I never noticed additional torque at low RPMs with a quad mag.....never heard that as a benefit either. The big thing with them is more power in the mid and high range, plus they had less of a cogging effect.....in crawling you get less of a snap as the armature spins at very low speeds.....aka, its smoother. Later EddieO |
05-26-2010, 02:22 AM | #10 |
had a look at the warrior II 45t but they're out of stock i think i'm going to go with the novak goat 3s brushless or the M2 Dig when it comes out! anyone has a good recomendation for a novak brushless motor setup or should i just go with the 21.5t that comes with the goat combo?
05-26-2010, 03:17 PM | #11 | |
06-01-2010, 02:37 AM | #12 |
hmmm ok how about the M2 Dig then i can use it on my future MOAis it a good ESC?
06-01-2010, 02:06 PM | #13 |
