05-05-2010, 11:31 PM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: Moses Lake
| servo question?
I have a servo from ckrc, the wiggle, i do not havea lot of run time on but it seems to have lost all its torque and gets fairly warm after a short period of time. I do have a bec installed. Is this baby on the fritz already or can it be something else?
05-05-2010, 11:43 PM | #2 |
Rock Crawler Join Date: Feb 2010 Location: costa rica
on what voltage are you running it? If you have the skils you could take apart the servo motor and check the brushes.
05-05-2010, 11:58 PM | #3 |
i am an idiot when it comes to this stuff, so I do not know what the voltage is. How do i know?
05-06-2010, 12:12 AM | #4 |
well if you have a ccbec and just bought it new and installed it than you should have 5 volts. BUT if you arent sure you shoud test the voltage on the becs output with a voltage tester (multimeter). The bec can deliver any voltage, the max voltage is the same that delivers the battery and the lowest, if not mistaken, is 5v.
05-06-2010, 07:40 AM | #5 |
Its probably dying. Thats what happens to crap servos. I went through half a dozen of cheap $20 servos before I had the brains to pony up and buy a good one.
