05-06-2010, 08:58 PM | #1 |
Rock Crawler Join Date: Oct 2009 Location: Wasilla, Alaska
| Heat sink for mamba 5700?
Anyone know of a heat sink for the 5700, im running it in my slash 4x4 with a 3 cell and goes into thermal shutdown after about 15 min of hard running.
05-06-2010, 09:40 PM | #2 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
Might try dropping a tooth or two on the pinion. What gearing are you running now?
05-07-2010, 12:36 AM | #3 | |
Rock Crawler Join Date: Jan 2008 Location: Knoxville
if you need a heat sink something isn't right, most likely you are geared too high for the motor. In my opinion the 5700 is not a good motor for the slash, specially on 3s. Slashes really like the traxxas 3500kv motors, or an equivalent sized can. | |
05-07-2010, 01:18 AM | #4 |
Its the stock 13 tooth with the 54 tooth spur. It does haul a#$, it will leave over 10ft of black marks from a dead stop. not bad for a 4x4
05-07-2010, 08:12 AM | #5 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
I would drop it about 3 or 4 teeth. My stock vxl in my 4x4 slash gets warm on 3s. The Mamba Max and 5700 in my sc10 gets pretty warm on 3s.
05-08-2010, 10:16 PM | #6 |
Well i figured out why it was getting so hot. I was out playing with it today and pulled a couple wheelies when it just stopped, but i still had steering. went and picked it up and smoke started pouring out from under the body, as i was ripping the pins out more smoke started coming out. something in the esc decided to let go and blew a hole in the side of it, there was solder everywhere and black goo and this was what i was left with. It also melted the solder holding the wires in. So now im looking for a new esc, any suggestions? Last edited by AkFordfan; 05-08-2010 at 10:19 PM. |
05-08-2010, 11:56 PM | #7 |
Quarry Creeper Join Date: Mar 2009 Location: Peoples Republic of Kalifornia
Were you running a fan with your esc?
05-09-2010, 12:42 AM | #8 |
No, local shop didnt have one, this was after about 5 min today |
05-09-2010, 07:59 AM | #9 |
Rock Stacker Join Date: Nov 2009 Location: Drumheller
Ill bet it was your ESC going into thermal shutdown, not the motor. they dont shut down due to heat. get a mamba max ESC and you will be set.
05-09-2010, 08:42 AM | #10 | |
Damn, you're in Alaska? If you can't keep it cool there you definately have a problem. You should try that down here in FL. Last edited by Scattman; 05-09-2010 at 08:51 AM. | |
05-09-2010, 09:03 AM | #11 |
Its probably happened a handful of times, ya i probably would have a hard time keeping it cool down there it hit 60* yesterday
05-09-2010, 12:04 PM | #12 |
Quarry Creeper Join Date: Dec 2009 Location: St. Augustine
lucky, it hit 95 on my front porch yesterday but yea, get a mamba max and never look back |
