05-10-2010, 02:07 AM | #1 |
Newbie Join Date: Apr 2009 Location: Santa Clarita
| BEC for WINCH?
I'm running the CC BEC at 6.0v with my Goat 3s ESC. If I add a winch to my setup will I need a second BEC for it? I assume if I don't voltage to the servo will drop as it's sharing the power supply?
05-10-2010, 04:06 AM | #2 |
RCC Addict Join Date: Sep 2008 Location: Mccalla,Al
You will be ok with one, most of the time when your winching you are sitting still.
05-10-2010, 07:44 AM | #3 |
Rock Crawler Join Date: May 2009 Location: 354
05-10-2010, 09:01 AM | #4 |
Rock Crawler Join Date: Feb 2010 Location: costa rica
With the goat 3S you didn't really need a bec in the first place. The Goat 3s has a 5amp internal bec.....
05-11-2010, 07:52 AM | #5 |
Quarry Creeper Join Date: Oct 2009 Location: stephens city
if your runnin 3s on your goat3s you do need a bec, and you'll be fine with just the one
05-11-2010, 01:37 PM | #6 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
One BEC will be enough. But your winch will lack in power. Winches require about 7.2 volts to be able to use it to it's full potental. The second BEC is not required to make the winch work though I hope that helps. |
05-12-2010, 11:33 AM | #7 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
You can do a 2nd BEC and run it straight to your winch controller and program it at 7.2 so it gets the full power.
