05-16-2010, 03:08 PM | #1 |
Newbie Join Date: Dec 2008 Location: spain
| can somebody explain me the BEC thing?
hello: I have found that sometimes the HITEC servo does not have the power to turn the tyres. I solved that same problem on my full side Jeep with a hydro assist BUT being new to RC can figure out what to do. The BEC is the solution? Thanks Eduardo |
05-16-2010, 03:31 PM | #2 |
Rock Stacker Join Date: Nov 2009 Location: Drumheller
what servo have you got? a BEC might be the fix but if you have a weaker servo it may not help any.
05-16-2010, 03:36 PM | #3 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
Assuming the servo "needs" more power and it is not getting it from the ESC, yes, a BEC is probably the solution. As suggested - if it is just a weak servo, giving it more power will not help things. |
05-16-2010, 03:43 PM | #4 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
I have a question to go along with this thread. reguarding my E-maxx. I have a new servo, not the best but its the Waterproof one that comes stock on the new e-maxx's I can hear the servo turning but not turning the wheels when sitting still, only when I take off the tires will turn and then they turn great when driving. Would i need to add a additional battery source to the reciver to help the turning ? |
05-16-2010, 03:46 PM | #5 |
05-16-2010, 03:48 PM | #6 |
Yup, sounds like a squishy servo saver to me too.
05-16-2010, 03:53 PM | #7 |
cool, thanks guys, I just didnt know if i need more juice going to the servo, but i will try a better servo saver first and see if that helps out.
05-17-2010, 03:47 AM | #8 |
| the servo is HITEK HS640MG
Is that a weak servo? Can I get more power steering with any other servo? Thanks ed |
05-17-2010, 07:19 AM | #9 |
What servo are you using? HS640mg is not a Hitec model. If its a 645, they are decent servos but in no way the strongest. However they do respond quite well to higher voltage via a BEC. |
05-17-2010, 08:31 AM | #10 |
