05-17-2010, 12:32 PM | #1 |
Newbie Join Date: Dec 2008 Location: Grand Junction, CO/ Calgary, AB
| novak motor? I ordered a Novak Crawler 21.5 Brushless motor (NOVM3220)for my Goat 2s setup but the sent me a SS Pro 21.5 Brushless motor(NOVM3421) instead. could these be used? what is the difference? its going in my LCC shafty Last edited by Krawlerado; 05-17-2010 at 12:40 PM. |
05-17-2010, 01:38 PM | #2 |
Rock Crawler Join Date: Aug 2007 Location: Casper, WY
It looks like the kv is quite a bit higher on the pro (1,350 vs 1,800) but otherwise similar. Why not just contact the vendor and discuss it with them? If they're a reputable seller they'll make it right. Novak BL motor specs: http://www.teamnovak.com/products/br...spec_chart.htm |
05-17-2010, 01:48 PM | #3 |
Quarry Creeper Join Date: Jun 2005 Location: Las Vegas
seems like I remember that novak does something different on the crawler motors so the ECS knows it a crawler motor and gives you instant reverse... if you hook up a non crawler motor it reverts to a standard ESC configuration of forward, break, delay then reverse... might look into that because reverse delay SUCK'S.
05-17-2010, 01:51 PM | #4 |
i think you are looking at the ballistic motor....acording to that chart they have the same kv (1800), same watts (85), it looks like the only difference is .12oz more weight and green vs. brown timing ring and it looks like the crawler doesn't have the thermal protection
05-17-2010, 01:53 PM | #5 | |
you think? even with the ESC in worm mode (no brake) | |
05-17-2010, 02:19 PM | #6 |
I think so... I'd give novak a call. MOTOR COMPATIBILITY The Goat 2S Crawler is designed for use with sensor-based Novak 540-sized Crawler Brushless Motors -- 13.5T (#3414), 18.5T (#3419) and 21.5T (#3420). Using a Novak SS Pro motor (#3408-#3421) is acceptable, but the ESC will default to an XBR non-crawling default profile. Any motor used must have Thermal Overload Protection, which protects the system from overheating and damage. In fact, the ESC will only operate with brushless motors that have built-in thermal protection that follow ROAR guidelines. This sophisticated feature ensures a fun day at the track without the worry of overheating. For the complete list of compatible motors, click here. Last edited by JSN; 05-17-2010 at 02:23 PM. |
05-17-2010, 03:11 PM | #7 |
um i think so too i wish i had seen that before i posted thanks
05-17-2010, 03:35 PM | #8 | |
This statement is clear as mud to me... I understand you can run the motor and the ESC will default to a non-crawling profie... does that mean you CANNOT program it to a crawler profile or just you HAVE to program it instead of the motor telling the ESC Either way it would be best to KNOW before you hook up the motor and possible ruin the chance of returning it Good Luck! | |
05-17-2010, 05:53 PM | #9 |
i asked novak about that and they said no it just puts it into non-crawler mode
05-17-2010, 06:05 PM | #10 |
So you can't program the ESC for crawler mode using that motor? your stuck with reverse delay? Novak makes darn sure you use thier products exactly how they want you too... Any chance you can return it? maybe they will ship the correct motor the second time |
05-18-2010, 02:03 AM | #11 |
Pebble Pounder Join Date: Oct 2009 Location: South Korea
There is no way to force the esc into crawler mode. If I knew that I wouldn't have bought it: http://web1.rccrawler.com/forum/show...ght=Novak+goat |
