05-19-2010, 06:15 PM | #1 |
Rock Stacker Join Date: May 2010 Location: sterling
| How come
How come tekin fxr reverse have more drag than my forward ?
05-19-2010, 06:18 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
you mean the brake holds better when rolling forward then back wards?
05-19-2010, 06:26 PM | #3 |
When I'm in forward then I release sometimes will stop ! But in reverse as soon as I release it stops right away! I play with the DB already !
05-19-2010, 06:40 PM | #4 |
check the trottle trim on your radio, if its to far forward it will roll a bit, what TX are you useing? |
05-19-2010, 07:54 PM | #5 |
Got it ! Your the maaann! I'm using a stock tx and the throtle trim is on mid! Y my revers is faster than forward, but if I turn my trim for more forward it will go faster than reverse but then lose my DB |
05-19-2010, 07:57 PM | #6 |
get a hot wire, you can update the firmwear, it will made the esc smoother, and u can change the DB% rather then just setting by flasing leds, makes life so much easier haha
05-19-2010, 08:01 PM | #7 |
So my esc is not updated is that right?
05-19-2010, 08:08 PM | #8 |
correct, im not sure what version the come with but they current one is .030 ur lhs might have the hot wire installed on one of their comps (the one here has the HW and castle link on theirs) and would probably do it for free since u bought it there |
05-19-2010, 08:21 PM | #9 |
Even tho I just got this last week, still needs to be updated ha ! I'll check my local HS ,
05-19-2010, 08:24 PM | #10 |
haha ya, but there is no tellin when it was made , could have been in the ware house for a while, then to ur lhs , then there untill u bought it, i ordered mine off line and went from 028 to 030,
05-19-2010, 08:35 PM | #11 |
I'll call my HS Tomorrow and ask! Your so helpful man thanks
05-19-2010, 08:38 PM | #12 |
haha np, the weathers been pretty lame around here the last few days so other then work i have no reason to go out side hahaha so might as well try and be usefull
