05-20-2010, 07:41 AM | #1 |
Rock Stacker Join Date: May 2010 Location: -34.040361,151.214831
| esc settings
i'm setting up my first esc on my honcho trail truck , need some advise on the settings. it is a speed passion inspire crawler combo brushless running 2s 30c lipo 1800 or 3000 mah. I know its a bit much but any help is much appreciated . most of it i kind of understand to some degree just don't know what to set at, but drrs and amts well not real sure , one is when starting off the other is motor timing ??? 1.run mode - fwd w/brake - fwd/rev w/brake - fwd/rev 2.drag brake - 0-5-10-25-40-60-80-100 % 3.low volt cut off - 0-2.6-2.8-3.0-3.2-3.4 v 4.drrs start mode ??? - 1-10 levels 5.brake force - 25-50-75-100 % 6.rev force - 25-50-75-100 % 7.initial brake force - drag brake-0-20-40 % 8.neutral range ??? - 6-9-12 % 9.amts timing ??? - 0-3.75-7.5-11.25-15-18.75.22.75-26.25 deg 10.overheat protec - off/on 95degress |
05-21-2010, 06:29 PM | #2 |
this is how i've set it up so far 1.run mode - fwd/rev w/brake 2.drag brake - 40% 3.low volt cut off - 3.2 v 4.drrs start mode ??? - 1 level soft 5.brake force - 75 % 6.rev force -75 % 7.initial brake force - drag brake % 8.neutral range ??? - 6 % 9.amts timing ??? - 3.75 deg 10.overheat protec - on 95degress |
