05-20-2010, 06:02 PM | #1 |
Rock Stacker Join Date: May 2010 Location: sterling
| Jr rx3 on ax10
When I try to use my old xr3 I lost a lil bit of steering, does anybody here use the same tx and have the same problem? What is th reason y I have this small problem?
05-20-2010, 07:29 PM | #2 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
i use an xr3 on my crawler, xr3I on the rest of my stuff. ive found with both the potentiometers (both steering and throttle) get dirty and you can lose steering/throttle and cause all sorts of glitches. you can pull the radio apart, remove the pots, disassemble them and clean them with a pink pencil eraser. this is providing nothing has changed with the epa or steering %
