05-21-2010, 02:11 AM | #1 |
Newbie Join Date: May 2010 Location: Abbotsford
| Novak 17.5 SS Pro with 14mm Crawling Rotor?
Hi I was just wondering if this will work or if any one is using this right know and how it is going for them?
05-21-2010, 10:19 AM | #2 |
I would have to guess it to be about a 1500KV setup (there's no solid KV info out there for the big rotors) and would have to be used with a MMP or RS ESC, a Havok won't give proper drag or instant reverse and a Goat will turn into a Havok with that motor. The biggest issue with the Novhack silver cans is the non-replacable sensor harness, they seem to go out in the abusive crawler enviorment pretty quick.
05-22-2010, 04:07 PM | #3 |
YA the crawler i would put it in would be a losi comp crawler. the ecs that i have to use would be a MMP or a traxxas Velineon vxl-3s. I am currently using the mmp but I found the VXL-3s works a bit better because the esc cuts all power to the motor and steering when the wheels get locked in a crack, Then I have to pick up the crawler and it will start again and with the VXL-3s it did not have that issue.
05-22-2010, 04:13 PM | #4 | |
05-22-2010, 06:06 PM | #5 |
05-22-2010, 10:20 PM | #6 |
Not hard at all to wire in a BEC, the MMP is only 3 amp output. We had been powering a 5645 with no issue in a LNC with a MMP, swapped in a 9100t after stripping gears today and picked up the same issue. A CC BEC will solve it and let you run the MMP for instant reverse.
05-23-2010, 12:00 AM | #7 |
07-09-2010, 12:21 AM | #8 |
Pebble Pounder Join Date: Jun 2010 Location: Gresham
so the original question was never answered. i too have the 17.5 ss novak and was wondering if the 14mm rotor will work in this can. i see on the novak site that the largest rotor avail for this motor is the sintered 13mm. just wondering if anyone else has tried it. i love the speed of the 17.5 on a 14t pinion but the low end leaves a little to be desired.
07-09-2010, 12:41 AM | #9 |
RCC Addict Join Date: Jan 2005 Location: Germany north
07-09-2010, 04:25 PM | #10 |
thanx im gunna try it hopefull i dont lose that much wheel speed cause its perfect for me with the 17.5 with a 14t pinion just would like a little better low speed
07-09-2010, 04:30 PM | #11 |
07-09-2010, 04:54 PM | #12 |
