05-23-2010, 06:20 PM | #1 |
Quarry Creeper Join Date: Feb 2008 Location: EAST TN WHERE SHINE IS FREE
| dx3r problems please help
Thanks for looking i have a berg that i have built with 35t motors i bought used and i cant figure out why i get full throttle one way and very little in reverse no matter what i change on the radio nothing i still have no reverse and esc is set for foward and reverse any ideas? guys
05-23-2010, 07:16 PM | #2 |
Quarry Creeper Join Date: Jul 2009 Location: West GA, USA
Not sure if this will help you but anyways... I had a similar problem... I like having a fast reverse, so I swapped the motor rotation on my ESC where reverse was faster. Adjusting the EPAs and deadband helped to make things reasonable. It's not exactly a fix...more like a bandaid for a problem I don't care to understand. I have a Goat 2S and 18.5, DX3.0. |
05-23-2010, 07:39 PM | #3 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
What esc and settings? |
05-23-2010, 08:08 PM | #4 |
sidewinder with a punk dig
05-23-2010, 08:56 PM | #5 |
Quarry Creeper Join Date: Oct 2009 Location: St.Louis
Have you calibrated the ESC to the radio? Have you checked your EPA's. It is possible that the person that had the rig before you cranked up the end bell on the motors.
05-23-2010, 10:00 PM | #6 | |
Please help us help you, could you throw a little more punctuation in your posts, it makes them a lot easier to read. | |
05-24-2010, 07:15 AM | #7 |
05-24-2010, 07:45 AM | #8 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
| First he needs to calibrate the ESC to the Transmitter. Changing settings on the ESC with the Castle Link will not help his problem if the radio and speed control are not calibrated to each other. |
05-24-2010, 09:10 AM | #9 |
ok thanks guys.I have the castle link. Now how do i calibrate the tx and esc together
05-24-2010, 06:00 PM | #11 |
after recalibrating the radio and esc it still does the same thing
05-24-2010, 06:02 PM | #12 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Too much advanced timing on the motors would be my guess.
05-24-2010, 06:09 PM | #13 |
How do i check that ? i have tried two different motors with the same result |
05-24-2010, 07:20 PM | #14 |
I don't remember if the sidewinder has a reverse strength/% setting?
05-24-2010, 08:43 PM | #15 |
Quarry Creeper Join Date: Apr 2007 Location: Northern PA where the rocks grow wild
I had a similar problem, even after re-binding & re-calibrating numerous times my rig was still glitchin & had minimal power. I called the tech dept. at horizon/spektrum & they walked me through a fix & it worked fine ever since. It was somethin simple but I can't remember exactly what it was. Make a 15 min. call & they can guid you through fixin it.
05-25-2010, 12:50 AM | #16 | |
This will help. http://www.misbehavin-rc.com/pit-lan...tor-timing.asp | |
05-26-2010, 12:44 PM | #17 |
Well i checked to motors out last night and thats not the problem.I am now offically stumped this time.
05-26-2010, 03:09 PM | #18 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
I had a customer in the other day that had a similar problem with his DX3R. He had the brake adjustment turned down to zero and he turn off the brake adjustment in the Switch Selector section of the radio. Make sure your BRAKE adjustment is 100%, shown at the bottom of the main screen under the steering and throttle trim. It is adjustable via the 'E' button if you are using your default button allocations. Check in the MONITOR section of the radio to make sure that you are getting full travel in both direction from the throttle channel. |
05-26-2010, 03:26 PM | #19 | |
RCC Addict Join Date: Apr 2008 Location: Georgia
I believe the sidewinder does. The castle link would allow you to have the same reverse speed as the forward throttle or adjust it to be slower compared to the forward speed. Have you tried to run a different TX and RX setup. Maybe hook up an old Traxxas ( or whatever ) TX/RX combo and see if your reverse is still slower. If so it may be some adjustment on the DX3R and not the motors or ESC. | |
05-26-2010, 08:01 PM | #20 |
i have 3 dx3r's laying here and its the same with all of them. I just tried a different sidewinder esc with no change in results.Now can it be the punk dig switch?
