05-25-2010, 08:23 AM | #1 |
Rock Stacker Join Date: Apr 2007 Location: Longmont
| sidewinder wont respond
So I got a sidewinder from a friend, I wired it all up as it should be for a brushed motor and when I turn it all on it has no throttle response...Ive tried to reverse the throttle on the radio, trim the throttle on the radio, a series of turning one thing on before the other and nothing. I have steering servo response though so I know the radio's talkin to the reciever. Any help is appreciated |
05-25-2010, 08:29 AM | #2 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
Did you calibrate the ESC to the radio?
05-25-2010, 08:32 AM | #3 |
Quarry Creeper Join Date: Oct 2007 Location: Ft. Wright, KY
When you have everything turned on in neutral position, what is the led on the speedo doing, ex. solid yellow, flashing yellow, flashing green?
05-25-2010, 08:43 AM | #4 |
A while back, Castle had a version of their software that had problems with the different motor leads. Try swapping around the motor leads.....instead of using red and black, try white and black.
05-25-2010, 08:51 AM | #5 |
Newbie Join Date: Sep 2004 Location: ATL
Was the last owner running brushed or brushless? if it's set up for brushless you will have no throttle until it is reset to brushed mode.
