05-25-2010, 04:17 PM | #1 |
Rock Stacker Join Date: Mar 2009 Location: lake odessa
| Brushes 35t tekin
how small does the brushes get till u have to replace them????? not really happy with the 35t FX-R system ran it 3 time with 2s and now it does not even work...
05-25-2010, 05:34 PM | #2 |
Brushes should last a really long time in a crawler. Was this system new when you installed it? You might just have a brush that is hung up and no longer making contact. Pull on the lead that is connected to your brushes and make sure they aren't stuck.
06-07-2010, 03:43 PM | #3 |
the brushes are still long.. i have done everything to this motor to get it working again.. cleaned and cleaned.... nothing has helped some one want to buy the system??? lol it was a sweet system when it worked
06-07-2010, 03:44 PM | #4 |
Alright, so the next step would be to try a different motor, if you have one on hand. Or, if you're willing, you should disassemble the Tekin motor. You might find something you couldn't see before. |
06-07-2010, 03:45 PM | #5 |
I'll give you $10. Try hooking the motor directly to a battery. If it spins you've got other problems. |
06-07-2010, 03:53 PM | #6 |
The problem that I typically encounter with motors is a stuck brush. It will stop the motor in its tracks...
06-07-2010, 04:36 PM | #7 |
well the only thing i have not tried is the battey thing... whats the problem if it spins??? this sux i like this setup when it worked,....
06-07-2010, 04:45 PM | #8 |
Rock Stacker Join Date: Nov 2009 Location: Drumheller
If it spins then you have ESC problems.
06-13-2010, 05:29 PM | #9 |
RCC Addict Join Date: Jul 2009 Location: Near Boston
| problems
I have seen the magnets in the case come loose and get stuck on the stator (the core of the motor that turns). If you put the motor directly to the battery and it does not turn this is worth looking into. Remove the screws and pull the stator from the case. make sure to not loose any of the washers or bearings. Make sure everything looks in place in the stator and the core. I had this happen just the other day to my friends 55t. Brian BostonCrawlers.com |
