06-07-2010, 08:20 PM | #1 |
| Help Needed: Sidewinder and Brushless outrunner issues
Just hooked up a 2580kV Scorpion HK 2221-12 to the sidewinder. Setup the sidewinder for brushless and everything else at stock spec. Running a BEC and 11.1v lipo. Hooked it up and calibrated the ESC to my radio. It has been in brushed mode. Gave it a few throttle pulls, little bit of hesitation then it gets going. About 3 or 4 throttle pumps its turning fast, then it starts hesitate. I can hold the throttle at full and it will just kinda "jump" at like 1/25 of the throttle all glitchy like. Unplugged everything, re-calibrated, plugged back up. Now it just kinda cogs int the direction Fwd/rev and gets kinda warm fast. This is not hooked up to a trans either. Oh, and the castle beeps went away after the first calibration! Tips, comments, suggestions? Last edited by Szczerba; 06-07-2010 at 08:23 PM. |
06-07-2010, 08:27 PM | #2 |
Quarry Creeper Join Date: May 2010 Location: Plumas county
Try to reprogram your sidewinder. Idk why, but, mine has jumped out of brushless mode to brushed a couple times after running a brushed motor. Usually afteritsits for a week or 2. Also check your throttle expo or linear curve if using the castlelink. Maybe even the nutreal deadband? Hope you find the reason.
06-07-2010, 08:34 PM | #3 | |
whatca mean by throttle expo or linear curve. I have those set to base, or straight line. Not seeing a neutral deadband. Seeing a throttle deadband. | |
06-07-2010, 08:37 PM | #4 |
I agree that is sounds like its in the wrong mode. I've done that a couple times.
06-07-2010, 08:38 PM | #5 |
It's in brushless mode.
06-07-2010, 08:40 PM | #6 |
Try a different bl motor and see what it does.
06-07-2010, 08:59 PM | #7 |
ok, aligator clipped it to the 8ight-e 1700kv monster and the sound is back it's blowin' and goin'. Ok, so it's the brand new motor I just hooked up? WTF? Its rated for 4S. So, now what? That's all I get is a few pulls of the trigger for a "Competition Series" Helicopter outrunner? FYI. 4mm barrel-ended alligator clips work great for connecting to 3mm esc barrels! Last edited by Szczerba; 06-07-2010 at 09:08 PM. |
06-07-2010, 09:10 PM | #8 |
Try hooking it up differently. I don't know why, just a thought. If that doesn't work, hit it with a hammer. |
06-07-2010, 09:13 PM | #9 |
I tried swapping the red/black wires on the esc/motor still the same. No binding, cause its off the trans and the red wire is pulled from the esc for the BEC, etc. It ran great the first 3-4 throttle pumps then it started running super slow and twitching every 2-3 seconds and getting hot. Fix it Duuuuuuuuude! |
06-07-2010, 09:19 PM | #10 |
Did you hit it with a hammer yet? That fixes everything. |
06-07-2010, 09:21 PM | #11 |
| No, not yet. It still could be using as fishing weight or an armadillo projectile. Guess I wil trying giving Amainhobbies a call tomorrow and see what they can do to get me in touch with Scorpion motors. |
06-07-2010, 09:22 PM | #12 |
Try swapping all three of the wires around, not just the black & red.
06-07-2010, 09:34 PM | #13 |
alright. I'll give it a once over tomorrow afternoon. Thanks for the help.
06-08-2010, 01:06 PM | #14 |
Just talked to a guy at innov8tivedesigns.com (AMainHobbie's Scorpion Motor Supplier) and he said it sounded like only 2 of the 3 phases are getting power. Since the motor is glitchy and quivering. It is probably a bad connection or cold solder in the bullet connectors I soldered to the ESC or the ends of the male connectors coming from the motor could be gummed up. I'll check it out later. |
06-09-2010, 08:40 PM | #15 |
Now that I think of it, it does sound like a wire isn't connected or the white/signal/what ever wire is in the wrong place. Or the esc is gone but if it works for another motor.... Hope you find your problem!
06-09-2010, 08:42 PM | #16 |
It was the male barrel connectors that come off of the motor. They were suppost to spin freely. They weren't. I just moved them around a bit and plugged em back into the esc female ends and blamo. Fired up. I guess some solder or solder flux was jammed in there or something causing a bad connection. |
06-10-2010, 03:36 PM | #17 |
Glad your not stuck without a motor! And a quick easy fix at that! |
