06-25-2010, 03:59 PM | #1 |
Quarry Creeper Join Date: Mar 2009 Location: Torrance, CA
| Can I power a winch and servo from the same BEC?
Using a Y adapter and changing the plug, will my CCBEC be able to power the winch as well my steering servo? Sorry if this has been covered before but I my searchfoo is weak. Thanks!
06-25-2010, 04:53 PM | #2 |
Depends on the amp pull. What steering servo, what winch, what battery voltage, what output voltage will the BEC be set at? Your infofoo is weak as well. |
06-25-2010, 04:57 PM | #3 |
You ain't got enough info foo'! |
06-25-2010, 05:54 PM | #4 |
Ha, sorry. Was posting from my phone and trying to keep it short. Anyway, 3Racing winch, servo is basically a MG945, 3s lipo, Tekin FXR, CCBEC. BEC is set at 6 volts but I may bump it up to 7.2 volts.
06-25-2010, 06:02 PM | #5 |
| You will be fine whether the BEC is at 6V or 7.2V, that servo doesn't pull much for amps. |
06-25-2010, 06:03 PM | #6 |
RCC Addict Join Date: Sep 2007 Location: WHEAT RIDGE, CO
I did it, worked fine.....
06-25-2010, 06:22 PM | #7 |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
The Castle BEC is rated at 10 amps, more than enough for those two accessories.
06-25-2010, 06:33 PM | #8 |
He could probably plug his phone charger into the BEC too, so he could charge it while he was crawling.
06-25-2010, 07:05 PM | #9 |
08-22-2010, 05:11 PM | #10 |
Rock Crawler Join Date: Feb 2010 Location: Hayesville
I know this is a little old. I have a 3racing winch on the way with a cc bec. My current setup is a sidewinder with hitec 645 servo handling steering duties with a cc bec set at 6v. My plan was to add the second bec set at 7.4v for the winch. Am I doing the right thing or am I just wasting a bec?
08-22-2010, 07:34 PM | #11 | |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
I run that setup at 7 volts with a stronger servo on one Castle bec with no issues on my scaler. That is with a Sidewinder on 3s with a h/w 35 turn. I even run some led's off it as well. The extra voltage really helps the 645 and the winch is still strong enough. Last edited by Scattman; 08-25-2010 at 05:24 PM. | |
08-22-2010, 07:38 PM | #12 | |
08-25-2010, 05:27 PM | #13 | |
My 645 is still going strong, been over a year so far. | |
