06-29-2010, 04:02 PM | #1 |
Quarry Creeper Join Date: Apr 2008 Location: Houston
| Novak Goat 3s support dual brushed motors?
I am pretty sure the Goat 3s will support dual brushed motors, I just cannot find it anywhere and their support can be real slow. Any help will be greatly appreciated. * |
06-29-2010, 04:06 PM | #2 |
Yep. Their site says 27 turns, which is more or less two 55 turns in parallel.
06-29-2010, 04:09 PM | #3 |
06-30-2010, 06:45 AM | #4 |
One more question: The Novak Fifty-Five motors are recommended for this ESC, but the specs on the motors say 2s max. Will those motors NOT work with this ESC and 3s? Thanks for any help. * |
06-30-2010, 07:04 AM | #5 |
Those 540 motors should not have any trouble with 3S...
06-30-2010, 07:14 AM | #6 |
Thanks for your help. This crawler (1/5 extended Killer Krawler) is not going to need much speed nor will it be competing on any large rocks or anything. I am setting this up as a demo for NASA and it will be driven by spectators remotely using camera's. So 2s might work for this, but I want to cover all of my bases before I have NASA spend the money. Originally I was going for Novak's M2 Dig Dual ESC and 2 Fifty-Fives, but that ESC is STILL not released!! I guess if i am only going with 2s, the regular Goat or even the Rooster should work, right? Thanks again! * |
06-30-2010, 07:26 AM | #7 |
Yep, they should work perfectly on 2S...
06-30-2010, 07:44 AM | #8 |
| Ideally, I want to use a single Goat 3s esc, 2 55t brushed motors and a single large capacity 3s battery. Will this work? And do you think 1 single 2s would be enough to move this large scale crawler if I had to use 2s? (It's bigger than a Baja 5B but lighter) Thanks again. * |
06-30-2010, 07:47 AM | #9 |
Hummm.....I dont have any experience with that crawler, so I am not sure on the gearing. But if it's anything like the Super Bully's gearing (65:1 at the axles), then those 55T motors should work fine. I run my super bully on 4S most of the time, 3S some of the time and the torque is there, but when I step down to 3S, the wheelspeed decreases. You know, if you are concerned about the ESC being able to handle the voltage of a 3S, then you might want to look into the Holmes Hobbies Torquemaster: http://holmeshobbies.com/product.php...4&cat=0&page=1 |
06-30-2010, 07:56 AM | #10 | |
My biggest concern is using 3s with those motors. The motors have already been bought. Novak says motor limit is 2s. Even though they are not going to need speed, I am not sure 2s is going to be enough. * | |
06-30-2010, 08:04 AM | #11 |
Well, I've been told by the guy who build the motors at Fantom, that really 3S shouldnt be run on 540 motors, but that they should be fine. He mentioned this when I was asking him why I kept smoking the motors in my super on 5S (~21V).... |
06-30-2010, 08:34 AM | #12 |
| He would be correct, they are (machine wound motors) really only rated for 12 volts
06-30-2010, 08:37 AM | #13 |
Well, the Fantom motors are hand wound, but I still havent had any issues with them on 3S (or even on 4S)....just when you bump up the voltage.... 3S is 12.65V peak. |
06-30-2010, 10:56 AM | #14 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
I have run novak motors on 3s without any problems?
06-30-2010, 11:05 AM | #15 |
12-02-2010, 01:11 PM | #16 |
Rock Crawler Join Date: Jul 2009 Location: greeley
| how could you dig? |
12-02-2010, 01:19 PM | #17 |
