06-29-2010, 07:54 PM | #1 |
Rock Crawler Join Date: Feb 2010 Location: Sturgis
| tx/rx matching
I just bought a used futaba 3pm , and I have an airtronics reciever . Both of them are in 75mhz ,but niether have crystals . So when shopping for crystals do I need to stick to Futuba tx rx crystals or futaba tx and airtronics rx crystals? Thanks in advance -Bob
06-29-2010, 08:04 PM | #2 |
Quarry Creeper Join Date: Jun 2005 Location: Las Vegas
won't work... futaba is positive shift and airtronics is negitive shift. No matter what crystals you try they will not talk to each other PERIOD. You'll need a futaba OR hitec 75Mhz receiver with the same brand crystals... in other words hitec crystals for hitec receiver and futaba for futaba. |
06-29-2010, 08:13 PM | #3 |
so hi tech will "talk" to futaba ?
06-29-2010, 08:22 PM | #4 | |
I run a mix of hitec receivers both dual and single conversion on either my 3pks or the couple of 3PM's I still have kicking around. On a side note I use a spektrum module on my 3PKS as well... just noticed the antenna is cracked at the base where it folds I've only had it a few months and have been EXTRA careful with it. In all the years I've been using 72-75 Mhz radios(20+) I have NEVER broken an antenna... I did wear a few out after YEARS of use. | |
06-29-2010, 08:23 PM | #5 |
I frickin called futaba and asked them about adding another vehicle to the ten model memory and they said as long as its 75mhz and the same channel I would be fine. Sucks when tech dosent know their own product.
06-29-2010, 08:32 PM | #6 | |
Huh...new one to me... If this were true why did novak make thier XXL receivers shift selectable? seems like it would have been a waste of effort Unless something has changed Airtronics/JR will not work with Futaba/hitec. I did get the shifts wrong in my first post... old age bad memory futaba/hitec is Negitive shift and Airtronics/Jr is Positive. | |
06-29-2010, 09:12 PM | #7 |
Thanks for your help .
