07-06-2010, 09:21 PM | #1 |
Quarry Creeper Join Date: Mar 2008 Location: Casper
| Xcelorin esc issues
This is the 3 rd system I have gotten from losi and am still not happy. This one works but when you turn it on nothing. In order for it to work everytime you have to calibrate it each time. What did I miss?
07-07-2010, 02:40 PM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: mesa
when it does this do the lights turn on?when mine sits for a week it acts up the lights don't come on and i have to unplug the esc from the reciever then it works ok.like you i am on my third system this one has lasted the longest
07-07-2010, 04:20 PM | #3 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
It could be something as simple as your throttle nuetral trim being out (not centered). If not set a center then it will still calibrate but when you turn it off and then back on it will not reconise the nuetral (center) setting of the radio so it wont arm the esc. As Joe mentioned do you get any lights (or sound) on the esc at all when you turn it on? I havent had any problems with my Xcelorin esc, touch wood. |
07-08-2010, 02:04 PM | #4 |
I too have had issues with the Xcelorin ESC (specifically, the 1/18th). Here is what I have found is the "proper" way to calibrate them. 1) Turn on the Transmitter 2) Plug in the battery 3) Push and hold the calibrate button 4) Turn on the switch for the ESC 5) First, the yellow/orange light will be illuminated....to not touch the trigger on the Tx 6) The green light will start to flash....push the trigger to full reverse (yes, reverse). 7) The green light will stay solid and the motor will beep 8 ) The red light will start to flash.....pull the trigger to full forward throttle (yes, forward). 9) The red light will stay solid and the motor will beep 10) The blue light will flash....leave the trigger at neutral 11) The blue light will stay solid 12) The blue and yellow lights will stay solid 13) Turn the ESC switch to off and unplug the battery 14) Plug in the battery and turn the ESC switch on For some strange reason, this works on my Xcelorin ESC...it might work for you. Last edited by JeremyH; 07-08-2010 at 02:10 PM. |
07-11-2010, 06:46 AM | #5 |
Quarry Creeper Join Date: Dec 2008 Location: Ramona
mine ran fine for about up to 10 battery cycles, then it just doesnt work anymore. The fan was on for one second then everything stopped. |
03-09-2014, 07:32 AM | #6 |
Pebble Pounder Join Date: Apr 2005 Location: wellington,co
Jeremy that worked great for mine. Sent from my SCH-I605 using Tapatalk |
