07-08-2010, 09:50 AM | #1 |
Rock Stacker Join Date: Oct 2009 Location: Canada
| Tekin FXR BEC
Is the Tekin FXR no good for general scale use? I have heard alot of stories of people using BEC witht he FXR. I will be using a Traxxas waterproof servo and don't really want or see the need to run a BEC for this. I am not competing, just having fun. Would I be better off getting a Novak Rooster Crawler instead? |
07-08-2010, 09:53 AM | #2 |
Rock Stacker Join Date: May 2010 Location: N/A
I run a 2.2comp with a FXR and have no external BEC. I only have problems when I plug in a 3c battery. No problem running up to 9.6v with it.
07-08-2010, 09:58 AM | #3 |
If you are going to run a 3S lipo battery 11.1v, then a BEC is really needed with the Fx-R. I run the Tekin on my 2.2 comp rig, scaler, and had them on supers too.
07-08-2010, 10:34 AM | #4 | |
Pebble Pounder Join Date: Apr 2010 Location: Shelter Cove
07-08-2010, 10:43 AM | #5 |
Thanks guys. I will only be using 2S lipos so I'll go without the BEC. Cheers! |
07-08-2010, 03:26 PM | #6 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
You will be fine. The FXR really only needs the BEC on 3s in comp crawlers running higher powered steering servos. In a scaler 99.9% of the time it will not be an issue. I have been running mine for over a year on 3s in my SCX with zero issues if that tells you anything.
07-08-2010, 03:36 PM | #7 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
While I'm sure it will probably be ok on 2s with that wimpy servo, but why not spend the $20 and be sure to not let the smoke out? After all ya may want a winch and/or lights one day. |
