07-08-2010, 09:13 PM | #1 |
Pebble Pounder Join Date: May 2010 Location: Minnesota
| Weird ESC Problems
I got a interesting problem for some reason some times when I turn on my crawler my truck will go forward when I pull the trigger then some times it goes in reverse when I pull the trigger to go forward, I have no Ideah why this is. All I did lately was add the Spectrum Dx3e and a 35 turn motor? But if I revers the channel for acceleration it will go forward then if it was going in reverse.
07-08-2010, 09:17 PM | #2 | |
Rock Crawler Join Date: Oct 2009 Location: Greenville South Carolina
Make sure everything is plugged in correctly to your reciver or switch you motor leads aroung. put red in black and black in red? Hope this helps | |
07-08-2010, 09:35 PM | #3 |
Pebble Pounder Join Date: Apr 2010 Location: Shelter Cove
You should post more information about what you have if you want help. Like what brand ESC, and how it's wired up.
07-08-2010, 09:37 PM | #4 |
Mtroniks ESC maybe?
07-08-2010, 10:13 PM | #5 |
I got a LRP Automatic esc and a Integy Matrix Pro Lathe Motor 35T. I got the motor wired up right I believe on the end is a black cap indicating pos and neg and thats how I wired the motor. I think its just a cheap esc Im thinking of getting a new one soon, Im leaning in the rooster direction.
07-08-2010, 10:24 PM | #6 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
see that guy above your last post. go to his website and quit buying cheapo equipment and you'll be happy again. |
07-08-2010, 10:31 PM | #7 |
Yeah its not the esc I wanted a buddy of mine got me into crawling I got the axial ax10 artc and he gave me his spare stuff and Ive been replacing all of it as Ive went. A new ESC and a MIP drive shafts are next.
07-08-2010, 11:52 PM | #8 |
Rock Crawler Join Date: Jun 2009 Location: Minnesota
i hate to say it but lrp makes good esc's just not for crawling
07-09-2010, 09:09 AM | #9 |
Ah yes, it is the ESC. I had one of those and it did the exact same thing. Luck of the draw which way it thinks is forwards.
