02-16-2006, 10:32 AM | #1 |
Rock Stacker Join Date: Feb 2006 Location: Grovetown
| E-Maxx....55t Integy.....and ESC
Did a search on ESC's and found some good info, but still came up a lttle short. Building a E-Mxx based crawler, gonna be a single Integy 55t motor, through a GD600 to the tranny. 3800mah 7.2v stick pack, 645mg's front and back, 3 channel Traxas receiver..... So here's the newb question....I'm looking at this ESC, but I don't understand the electrica jargon enough to know whether ths will be, barely suitable, a good choice, a good choice witha margine of safety built in.......I am otally lost as to what I should be looking for.... http://www2.towerhobbies.com/cgi-bin...?&I=LXHSV8&P=7 SPECS: Length: 1.7" (42.5mm) Width: 1.7" (42.5mm) Weight: 1.7oz (47.5g) excluding wires Voltage: 4.8v-8.4V, 4-7 cells Typical Voltage Drop @20A: 0.160V Rated Current: 120A Motor Turn Limit: 14 turns and above BEC: 5.0V High Frequency: Yes Fail Safe System: Yes Multi-Protection System: Yes Connectors: Standard Tamiya style Setup: Automatic Any help or guidance on what I should be looking for, spec wise, would be a BIG help. |
02-16-2006, 10:52 AM | #2 |
Pebble Pounder Join Date: Oct 2005 Location: Ashville, Pa
this looks like the same esc check out this thread.Hase anybody used this ESC? |
02-16-2006, 11:06 AM | #3 |
Quarry Creeper Join Date: Nov 2005 Location: The Great White North
There is no way the BEC circuit on that ESC will handle the two 645 servos... So if you want to run it, you'll almost certainly need a reciever pack to power the servos. Best bet is probably this guy here... although unfortunately it looks like it is currently out of stock. http://www2.towerhobbies.com/cgi-bin...&I=LXKYN6&P=ML |
02-16-2006, 11:33 AM | #4 | |
OK, so what I'm getting out of this is the "BEC" spec is important, what should I be looking for under that spec? What does BEC stand for? I really only wanted to run the single stick pack, but this is all new to me. So with the Tekin Rebel, I can run 4 wheel steering, and use only 1 battery, correct? Quote:
02-16-2006, 11:38 AM | #5 |
BEC stands for battery elimination circuit. Basically, instead of using a seperate battery pack to power the reciever and servos, the BEC allows the ESC to supply power to them. You're going to want something with Specs of 5.0-6.0 Volts. and at least 3 amps on the BEC. More is always better tho. And yes, the TR2 would be more than up to the task. |
02-16-2006, 11:51 AM | #6 | |
COOL!!!!!!!!!!!!!!!!!!!!!! THat's the answer I was looking for. That put eerything into perspective, I appreciate the help. Quote:
02-16-2006, 06:52 PM | #7 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Yup, Rebel 2 is a good choice. You get that XX4 set up yet? |
02-17-2006, 05:30 AM | #8 | |
So I'm sending hm a M.O. today for $90.00......2ea, 55t Integy lathe motors, a Rebel2, and a GD600, all N.I.B. Is that a sweet deal, or what ?????????????????????????????????????????;) | |
02-17-2006, 06:07 AM | #9 | |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
02-19-2006, 06:41 AM | #10 |
Newbie Join Date: Jan 2006 Location: parkersburg
lmao smile like a doughnut and peck like a chicken |
